I have redirected my fronts to Zone 2. This works perfectly and the speakers in my study are now powered by the 1067 front channels (a 1080 does the main zones fronts), but I cannot get any audio from the Zone Out RCAs. Must something be set for this to work or does it de-activate when Zone 2 is redirected?
1067 Zone Out problem
It seems as if nobody has picked up this problem before. However, I did a factory default reset to de-activate the Zone 2 redirect. When I switched the 1067 on again, there was an audio signal from the Zone out outputs at the back. When I redirected the fronts to Zone 2 again, the signal disappeared.
I cannot understand why Rotel should want to disable this audio out feed which would have been very useful for running a TV in the Zone 2 room fed by the Zone out audio!- Bottom
by larsHello All,
Trying to get zone 2 working. Analogue in as CD, redirected from center backs towards Large2 configured speakers.
Unfortunately, all I get is a hum from the chassis of the 1067, nothing at all from the speakers -
Any thoughts, suggestions or comments...-
Channel: Club Rotel
by selfilmHello,
I am new to this forum. I am an audiophile with some restrictions to my location - I live in Brooklyn so space is limited, hence the need for smaller Quad Bookshelf speakers and the need to use a Sunfire Subwoofer even though I normally never use Subs. That being said here's where things...-
Channel: Club Rotel
by focusIs it possible to have different crossover seettings on the LFE/SUB? For 2 CH i have set the fronts to small and their HP-filter set to 60 hz and the sub (redirected bass) set to 60 hz. I'm very happy with these settings, but the problem is, when i'm listening to a 5.1 mix, the LFE channel get "chucked"...-
Channel: Club Rotel
by RockShow01hi all:
i understand that my rsx-1067 will not pass a digital signal to zone 2. i am currently using an optical connection from a series three tivo box and am not getting sound passed to zone 2 (sq in zone 1 is amazing!!!), but i want to know if i can get sound passed to zone 2 by connecting...-
Channel: Club Rotel
by methrilI'm having a tough time finding a quality crossover to filter the full range line-level signal from my receiver's pre-outs prior to running them through a separate 2-channel amp (NAD C370) to power the 2nd set of subwoofer voice coils on my Gallo Reference 3's. Guess I'll just have to wait for the Gallo...-
Channel: Club Rotel
06 July 2005, 01:29 Wednesday -
- Loading...
- No more items.
