1067 - zone 2 problem
  • lars
    • 49
    Hello All,
    Trying to get zone 2 working. Analogue in as CD, redirected from center backs towards Large2 configured speakers.
    Unfortunately, all I get is a hum from the chassis of the 1067, nothing at all from the speakers -
    Any thoughts, suggestions or comments are most welcome -
    Thanks in advance,
    Lars
  • lars
    • 49
    Actually, is anyone using the zone 2 functionality on a 1067?
    Lars
    • lars
      • 49
      Okay, playing with this a bit more I find that the 1067 just will not accept the redirect. When I select it in the Default menu, and change it...then exit the menu, then return to the default menu the forward setting remains always at 'No'
      Can't change the tuner region setting either, though I don't need to at this time.
      - Lars
      • Kevin D
        • 4601
        I believe after setting those settings you need to perform a factory reset for it take effect.
        Kevin D.
        • lars
          • 49
          Hello Keven, and thank you for your post -
          I have tried a factory reset to no avail; I've also re-installed the upgrade, also to no effect unfortunately.
          It would be good to know if anyone else is running 1.2.2 and seeing the same problems, as I suspect that this is software related -
          Lars
          • Kevin D
            • 4601
            Are you sure you did the factory reset immediately after selecting the redirect feature?
            Kevin D.
            • lars
              • 49
              Thanks Kevin,
              A bit non-intuitive that, but it works - and thanks very much for your help!
              Lars
              • goldenmember
                Rotel 1067 on screen menu
                by goldenmember
                Hi, I am the proud owner of Rotel's 1067 receiver. My problem is that no matter what I try I can't bring up my OSD anymore. I've tried through each of my video outputs and nothing. I believe that through all this I have messed up some other settings. If I could simply reset everything and start over...
                13 March 2005, 18:41 Sunday
              • lars
                1050-E,1067,1080 Muffled Sound, Low Volume
                by lars
                Hello All,
                I haven't been very happy with the sound from my setup, so as a last ditch effort (because I just didn't want to believe the problem is my 1067), I tried connecting a 500 Euro Yamaha receiver and, rather unfortnately, it sounded considerably better than my considerably more...
                06 May 2007, 09:10 Sunday
              • njarwala
                RSX-1560: Using CB Amps for Zone 2
                by njarwala
                I have a Rotel RSX 1560. My setup is 5.1 and I do not have Center Back speakers. I want to configure the receiver so that I can use the two Center Back amps to power speakers in my backyard - as Zone 2. I can't seem to get it to work.
                Here is what I have already...
                04 May 2012, 21:54 Friday
              • Toolman
                1067:Default Surround mode
                by Toolman
                I recently purchased my first ROTEL product: RSX-1067 receiver and I love it!
                I am presently running it with 6 speakers (+ sub) and I frequently use it for listening to music channels through my satellite receiver. I prefer the sound of "7 channel stereo" but I have been unable to make...
                14 May 2005, 17:02 Saturday
              • Toolman
                1067: Default Surround Mode
                by Toolman
                16 May 2005, 06:06 Monday
