Rotel Kit and UPS's
  • Fishy
    • 299
    Rotel Kit and UPS's
    OK, I wonder about burst type surges in electricity that my equipment will put on the cabling in the house.
    To combat this I am thinking of installing a UPS to deal with this sort of thing, with a plus side being that I would get a clean(er) supply of power coming in, with surge protection built in a standard.
    OK I sort of understand that the type of output waveform will impact of the type of sound, but most all UPS's nowadays output a Sinewave waveform. Or am I wrong on this?
    This is what I am looking at!, or do I need a bigger version.
    It needs to be able to deal with an RSP-1098, RMB-1095 and an RDV-1050.
    Thanks in advance.
    Fish
  • Taito
    • 226
    Hi Fish, I'm not too sure about UPS's, but if you plug your 'protected' audio equipment into an 'unprotected' display or other component, a surge entering your display can easily travel down your interconnects and damage your audio equipment.
    Also, I very much doubt that 1000VA is anywhere near enough. The two transformers in your 1095 alone have a combined rating of 2400VA.
    Your best bet is to try a similar post where Jon or Thomas will see it (DIY) - they know plenty about power supply/conditioning. Maybe what you want is balanced power?
    Bottom line, I definitly wouldn't rush out and buy one. Hope this is helpful, and good luck.
    Cheers, Ben
    • mjb
      • 1485
      Fish, I would definitely NOT add a UPS - and for a number of reasons. A UPS uses very high chopping frequencies, some artifacts and harmonics will be present on the output. Also, no way will a UPS be capable of providing the surge current, or instantaneous peaks you're looking for. Most UPS's are designed for computer applications. A filter and/or surge suppressor might be something to consider, but note these sort of devices rely on ground (ie, the surge is taken away to ground). Most Rotel kit is two pronged (no ground)
      - Mike
      Main System:
      B&W 802D, HTM2D, SCMS
      • johnvb
        • 23
        google "Brickwall" and Zero Surge" for surge protectors. Also Monster makes some for more $$$
        • Fishy
          • 299
          Thanks for your input guys.
          Fish
          • mikeyc
            • 38
            Ups
            I would recommend the UPC-200 from PS Audio. Its reasonably priced and offers surge protection plus line conditioning and most importantly does not limit current. This unit is made by a high end audio company and is specifically designed for high current units like your Rotel amps.
            • ti33er
              ROTEL 1066/1075 - APC 450 UPS Compatibility?
              by ti33er
              Hi again,
              My work is throwing out some perfectly good APC UPSs, and wonder if any of you delightful fellows know whether or not they would be able to support my ROTEL 1066/1075 units? (and if they are worth using anyway?)
              The specs are as follows: (I live in the UK and...
              07 May 2004, 07:10 Friday
              UPS for home theater?
              by PewterTA
              I was just curious (and wanted some more minds in on this), but what do you guys think of using a UPS for a HT. Specifically, this one from Eaton Powerware?
              My friend can get a good deal on these (works for them) and he says it does everything any good surge/conditioner does from someone...
              18 February 2007, 20:26 Sunday
            • Beermoney
              What are you using for line conditioning and surge protection?
              by Beermoney
              My latest conumdrum is what to get for surge protection and/or line conditioning. I have all the usual HT stuff: amp, pre/pro, DLP pj. My power fluctuates a lot during the summer when the HVAC cycles on and off. We also get thunder storms in the spring, so lightening is a worry too.
              05 February 2007, 20:52 Monday
            • John Holmes
              Surge protectors/Line conditioners
              by John Holmes
              I've been wondering, does the given protection from such a device ever wear down from normal use?
              These items seem to get more of a workload than any other piece of equipment. I know living in WA., LA., and now FL., all of these places have power outages at least once a week or more....
              27 September 2002, 18:15 Friday
            • john4618
              Whole House Surge Suppressors
              by john4618
              Anyone using a Whole House Surge Suppressor ???
              Do they affect sound quality vs. not using one ???
              Here’s the blurb I found for the APC: “APC’s Residential Surge Suppressors are the first line of defense against damaging electrical surges and spikes that originate...
              26 August 2004, 11:52 Thursday
