rotel rsp-985 and subwoofer, please help!
  • sickmint79
    • Mar 2004
    • 15
    hey all, i have set my system to as follows:
    main: large
    center: large
    surround: small/thx
    subwoofer: yes/thx
    i have compression off, dolby as auto/on - i put in spiderman 2 and have the system in dolby digital in thx mode. i put the s/w limiter setting at 0db. i get no noise from the sub during intro playback or when i choose scene selection which has some car crash transition screen. no noise whatsoever. any ideas ?
  • Kevin D
    • 4601
    With modern units you should at least have the .1 signal going out with that config, but I'm not sure how the 985 works in that regard. Try setting the center and fronts to small and see if you get all the bass information.
    Kevin D.
    • sickmint79
      • Mar 2004
      • 15
      when i set the s/w limit there is definately output going to the sub. however with dvd or the avia dvd guide i am getting nothing from the sub. i didn't try setting the fronts to small yet but i should get sub information regardless correct? i would prefer to have them set to large for movies and music
      • sickmint79
        • Mar 2004
        • 15
        appears it was actually some multi channel setting being wrong on my denon dvd-2900. thanks though!
        • Dave Duvall
          THX processing on the REF30 question
          by Dave Duvall
          Here is a quote from THX specifications:
          "The Bass Crossover removes low frequency information from the signals sent to the front speakers and re-routes it to a dedicated subwoofer."
          My question is this. If I have the B&K Reference 30 set to "no subwoofer"...
          24 July 2001, 18:21 Tuesday
        • Classe4me
          Classe and subwoofer crossover
          by Classe4me
          Hey fellow Classe owners, I am curious to know what kind of subwoofer and speakers you are running, what your personal preference is for your subwoofer crossover frequency, and whether or not you use the large or small setting for your front speakers?? I had somebody tell me NOT to use the THX setting...
          16 October 2008, 19:32 Thursday
        • renzo
          1098--No Subwoofer in 2 channel Stereo
          by renzo
          Just hooked up my new 803(D)'s. Changed speaker setting to large on 1098. I played a CD and noticed no bass from the Subwoofer in 2 channel mode...strange. Plenty of bass in 5 channel mode and dolby pro logic mode. Under speaker setting I scrolled to "YES" for subwoofer. Any suggestions?...
          16 April 2005, 17:24 Saturday
        • Aussie Geoff
          RSP 1098 Wish List V2.0
          by Aussie Geoff
        • wbk
          Setting subwoofer level with RDC-7
          by wbk
          I'm having trouble getting my subwoofer level up to the level of the other speakers in my system. I have an Integra Research processor and, when I try to balance speaker levels through my processor, the subwoofer (Revel B15) level is way down even if I decrease the levels of the other speakers (Legacies)...
          18 February 2003, 09:05 Tuesday
