This is no April Fools Joke folks. During the next couple of days, we will be picking a day to migrate HTGuide to a new server. We will have the same reliable service we have always had, as we are not changing Hosting Services, only moving to a new updated state of the art server! Support is working to coordinate things right now.
We will announce the date of migration from old server to the new server in due time. We hope to minimize downtime while the DNS propagates to our new IP address, and service is restored. But some downtime is inevitable.
I was finally done setting up for the night and wanted to watch a short DTS dvd clip. After selecting DTS on the DVD, the 1065 showed DTS on the front panel, but I got no sound.
Will it play Dolby Digital? The Rotel should automatically switch over to DTS. And, unless I'm still in my early morning fog, if it plays DD fine, then it should detect and play DTS. The Rotel is receiving the signal as indicated by the display which also means that you have selected the correct input, right? You turned on the power amp I'm sure. I only mention that because I forgot to do so when connecting a new piece of equipment once and wondered why no sound came out. I'm stumped for now. Have to be off to the dentist and a couple of errands. Anyone?
I'm not sure, either. If the 1065 flashed DTS, then it's getting a DTS signal from the DVD player. I was going to suggest checking the DVD player's internal setup and making sure DTS output is on. You're using the 1065 as a receiver and not as a pre/pro with an outboard amp, right?
I knew I was groggy this morning. ops: My brain read 1066, rather than 1065. Yes, so unless you're using a dedicated power amp, turning the amp on wouldn't be a consideration. Duh. Anyway, thanks wng.
ejfiii,
What are you using to connect the DVD player to your Rotel?
sorry for the delay guys. The damn cable company has to do a new drop to the house to get the cable modem to work - hopefully done tomorrow.
Anyway, the 1065 is set up with a 2 channle amp for the fronts and a two channel for the 6 and 7 center back channels. They are all on and functioning fine. On the DVD menu, you can select DTS or regular (which is DD). When I select DTS, the flag is read by the 1065 and the on screen status changes to DTS and the front display also relfects this change. But there is no sound from the system. I checked it again to make sure, and it was still doing it. The only thing I didn't try was skipping into the film a few chapters to see if it was just the first chapter that was the problem.
Don't just check the DVD menu....Check the DVD Player's setup menu. Often, DTS capability is shut off in DVD players until you manually order it to play DTS.
Okay, I have DTS set to on in the dvd menu, I think the problem may be a setting for PCM downconversion. There is a 96KHz audio sampling rate. I have not changed that that I can remember. I assume I want this set to 'no' so it outputs at 96KHz? It says this is the factory preset, so I would imagine it would be correct.
If anyone cares, here is a screenshot of the proper part of the manual:
I will try again tonight to make sure it is set correctly, but it makes sense to me that it is if it can decoded DD.
Okay, tried last night. All DVD settings were correct. Started playing the DTS version and no sound. Skipped a few chapters and it worked. Pushed stop and play again and it worked. I don't know if there was a delay in seeing the DTS flag from the dvd player, or if it was the first time the Rotel had seen DTS so it caused a delay? I think I also pushed the right arrow on the remote to check for new settings and that might have forced it the first time? Who knows, but it now works.
I have had my 1065 not play on dts mode. One of the first dvd's I played when i got my 1065 was Eagles HFO in dts. I got the pic & no sound, the rec. read dts on the front panel. After switching to cd than tuner & back to dvd the sound was there. I notice that using dts somtimes there is a delay for the reciver to start playing dts. I'm almost sure that my problem happens on the same dvd's. I have many dvd's that have dts & the 1065 has no problem but there is the few that almost always gives me a problem playing dts. When I run into the problem I first switch the reciver to tuner or cd than back to dvd, if that didnt fix it I eject the dvd & put it back in & start over. Once the 1065 starts playing & locks into the signal no problem at all. I dont think it is a reciever problem it may be just the way the dvd was mastered or the way my dvd player sends the flag to the reciver. To me its not a big problem it dosnt happen often. My Onkyo also has done that a few times & I have a different dvd player connected to it, leaving me to believe that it may be the mastering of the dvd itself.
Just got this one in the mail today from Buy.com. (I think it's released tomorrow) A review:
Let's cut to the chase: Overall rating, :5: This is one of the better loved Disney movies with a solid, engaging plot and a wonderful soundtrack. This DVD does the movie justice and is a great...
I just purchased a C1, and everything works fine except it does not pick up the DTS signal from my DVD player. I am playing a DTS movie set to DTS. The DVD player says it is outputing DTS 5.1. I have a 5.1 setup. There is just no sound. When I switch the DVD back to DD it works fine. The input...
I'm looking for a good (but not outrageously good) dvd player to hold me over until the HD/Blue laser issue is resolved. I'm willing to pay up to $500. I have an older model that glitches even on straight out of the wrapper DVD's. My other DVD player doesn't have this issue....
When playing DVD's with a DTS soundtrack the picture stutters and jerks. This problem Is not consistant as some DTS disks are ok. and the problem DVD's stutter at random (when playing the same scene the problem Is there but not In the same place). DD DVD's are OK, I have tried R1 and...
09 April 2003, 06:59 Wednesday
Loading...
No more items.
