Need some help with my system connectivity.
  • bimmer528
    • 87
    Hey all.. I have been reading and reading as far as what the best type of connection is for my rdv1050 and rsp 1066. Im sorry for those who may not want to answer since I have quite a few questions. Thanks in advance for anyone who will attempt to remedy my prob's. Thus far I have been using from my rdv's dig output to my 1066's coax input a tributaries av1 digital cable and a monster s video from the rdv to the 1066 as well.
    I know its personal preferance as far as the analog vs digital connection but my question is do I need both of these connected at the same time?
    As far as the audio out section of the rdv.. it consists of the sub out, rears out, center, fronts, ect.. Am I better off connecting all of these instead of the digital cable? If so.. where would I hook it up to the 1066. The only place where I see fit is the Multi-input but then again why would I even need to use the multi input?
    Then is component video better or s video? I have read in the Rotel 1066 manual that once I use the s-videos for some components, I need to use the s-video for all of them so then I cannot use the component connections correct?
    Then the dac's. Just by running the analogs I am using my rdv's dac and bypassing the 1066's. Using the digital output on the rdv then uses my 1066 dac correct?
    Can I use either one.. the 1066 or the 1050 as an external dac for other components?
  • Matt Sprouls
    1066/1055 internal DACs
    by Matt Sprouls
    Can anyone point me in the direction or list the capabilities of the 1066/1055's internal DAC's.
    I need to know if they can handle a 24bit/96khz bit stream?
    Matt
    18 May 2003, 01:33 Sunday
  • biekrx
    RSP-1066 vs. RSP-1068 vs. RSP 1069
    by biekrx
    I have been planning to buy an RSP-1069 for a while as I build up my home theater. Unfortunately, cash has gotten a little tighter than I hoped, and I still don't have a surround processor and the only display I have is a 12 year old 27" CRT. I can only fix one of these problems right now and...
    07 September 2009, 21:12 Monday
  • spiffnme
    RDV-1060
    by spiffnme
    How does this machine compare for CD and DVD playback. All I've ever heard about is it's wonderful DVD-A performance, which honestly is the least of my concerns.
    I have a cheap Pioneer 656A DVD/DVD-A player. Is it worth upgrading to the Rotel? I use the optical out of the Pioneer anyway,...
    30 September 2003, 12:37 Tuesday
  • slaikan
    Rotel RDV-1060 vs SoundBlaster X-Fi ExtremeMusic
    by slaikan
    I decided to upgrade my 5 Year old SB Live sound card in my PC to a X-Fi ExtremeMusic. Made a huge difference to how my PC speakers sounded. I then was interested to see how it compared to a RSP-1068/RDV-1060. I've been lurking around on these forums and have noticed a few people have gone the PC audio...
    25 April 2006, 11:26 Tuesday
  • j_nathalia
    RSP-1066 and IR out
    by j_nathalia
    I have (an old -) RSP-1066 in conjunction with a RDV-1093 (after my RDV-1060 had too many problems and was replaced by Rotel).
    My DVD player is stored in a cabinet so I have connected my IR out of the RSP-1066 to my RDV-1093.
    The problem is no signals are received by...
    03 May 2008, 09:30 Saturday
