Eight channel RCA to DB25 cable
  • SteveG
    • 31
    For those of you who have been looking, I've found a cable company that makes eight channel RCA to DB25 cables. The name is Cobalt Cables, and they sell over the internet.
    Steve Goff
    Steve Goff
  • Burke Strickland
    • Sep 2001
    • 3159
    Thanks for the info, Steve. I'll keep them in mind if I get a source that outputs 8 analog channels (so far, I'm maxed out at 6, which is covered by the supplied adaptor). OTOH, it would be nice to have a direct connection from the source outputs to the RDC-7's DB-25 connector without another set of plugs in the chain. I can't help but think the extra connections degrade the signal, even if only slightly. But for a hi-rez source, every little bit counts. :>)
    Burke
    PS -- Have you tried one of the 8 channel adaptors yet?
    • Steve Goff
      • Feb 2002
      • 186
      If you have a 7.1 system, as I do, you might want to think about using an 8-channel cable, since you can use an RCA splitter to send the rear channels to both side and back speakers. I have not yet tried their adaptor.
      Steve Goff
      Steve Goff
      • n9949y
        DB25 to RCA cable
        by n9949y
        Where can I get a DB25 to RCA cable?
        Am planning to buy a Blu-Ray Profile 2.0 Panasonic DMP-BD50 player which has 6 5.1 channel analog RCA audio outputs. My Rotel RSX-965 is equipped with a DB25 25 pin 5.1 channel analog audio input.
        23 August 2008, 02:00 Saturday
      • Steve Goff
        8 channel DB25 to RCA
        by Steve Goff
        If anyone is still wondering where to buy such an adapter, Cobalt Cable makes them for about $140. http://www.cobaltcable.com
        Steve Goff
        25 October 2003, 17:04 Saturday
      • ht_addict
        RMB- 1095 DB25 cable question
        by ht_addict
        Just curious if there is a DB25 to RCA cable out there that would replace the 5 cables already going from my pre to amp. Thanks
        ht_addict
        06 November 2003, 09:09 Thursday
      • Rotel4Life
        DB25 cable caused all my issues in RSP-985
        by Rotel4Life
        Got a used 985 from an auction site. Looks perfect but had a hum on all inputs, all sources, on mute etc. If it was on, there was a hum. Also there was an audio 'hiccup'- like a 1/2 sec pause in sound every few minutes. My setup worked perfectly with an RTC965, nothing changed but swapping the 965...
        19 December 2012, 02:11 Wednesday
      • ht_addict
        Using RMB-1095 DB25 connection question
        by ht_addict
        First off is anyone using the DB25 connection on the 1095? Have you tried RCA cables? Any difference in sound?
        I'm looking at replacing my RCA cables that I use to hookup between my pre/pro and 1095. Mainly to tidy up behind my rack. I'm interested in the CobaltCable DB25 to 6RCA
        11 January 2004, 07:46 Sunday
