RDC-7 Remote Codes and other Onkyo systems?
  • Greg Staten
    • Sep 2001
    • 17
    I'm wondering if anyone knows whether the RDC-7 is code compatible with any Onkyo system. The RDC-7 isn't included in the Crestron database and it occurred to me that the RDC-7 might be code compatible with Onkyo units.
    Burke?
    Thanks!
    -greg
  • Burke Strickland
    • Sep 2001
    • 3159
    greg -
    That's a definite "maybe". :>)
    First, if you take a look at the remotes provided with the top-of the line products for Onkyo/Integra/Integra Research, they bear a striking cosmetic resemblence. :>)
    More to the point, my Pronto TSU-2000 has a built-in command data base which includes a number of templates for Onkyo components. I can get my RDC-7 to respond to some of the commands contained in these templates, so it appears the command families are the same. But the implementation in a particular Onkyo/Integra/Integra Research remote may not be universally applicable to other products in the three product lines.
    For a given component and remote combo, there's one way to find out for sure. (Try it.) :>)
    Burke
    • Greg Staten
      • Sep 2001
      • 17
      Thanks, Burke. I'll probably do some fiddling with it this coming long weekend.
      -greg
