Advice / Help required - C2 keeps switching itself off
  • Rags
    • 185
    Has anyone come across this problem. My C2 keeps switching itself off after a couple mintues of listening. I cant turn it back on again via the remote or the front panel and have to resort to switching the power off from the back and restarting. It was working fine before I went on holiday.
  • nicholtl
    • 539
    Whoa, sounds like it's time to call their tech dept.
    • SpOoNmAn
      • Sep 2003
      • 518
      no idea. I just wish I had one! id almost feel lucky to have your problem!
      Theatre Photo Album (A work in Progress)
      GameTracker -My List-
      Life is short, Play it LOUD!
      • cameronl
        • 69
        this is happening to me as well
        hi there, after 10 hours of use mine is doing exactly this - i guess it means by c2 is stuffed....
        CaM
        • Rags
          • 185
          Basically its a design fault in the C2 controller. Something to do with rectifiying the power supply harness - I know of two other people who have had the same problem as me. You need to return it to Parasound for repair - however if yours is so new you should potentially insist on a brand new replacement.
          • nicholtl
            • 539
            Sorry this had to happen to you, Cameroni. I know it doesn't make you feel better, but even the most solid of companies occassionally turn out a lemon. Just look at Apple computers, which I incidentally swear by. A most solid product indeed, but their most recent line of iBooks had lemons up the wazoo. Denon's pre-September 2002 DVD player, the DVD-3800, had lemons out the yin-yang. All of Duncan Hines' Angel Food Cake mixes are lemons! So don't let this put a bad taste in your mouth...just yet.
            Do what the good man Rags says, ask your dealer or Parasound for a full replacement (if it's brand new, or hell, just ask for one anyway).
            • Rags
              • 185
              To reassure you - mine is working without problem now. Also I have found Parasound to have good cutomer support. Whilst mine was in repair they called several times to keep me upto date (the UK service agent CSE that is).
              Basically it is a "known" problem of which they have had several cases. The permanent solution is to remount the harness to another location which sounds relatively straight forward (I think ).
                Strange that this problem has happened to more than one person. You're right, Parasound is great about customer service in fixing problems. Definitely puts one's mind at ease, along with the 10 year warranty!
                • cameronl
                  • 69
                  dam, i was hoping i wouldn't have to return it
                  oh well....
                  thanks for the advice everyone.
                  CaM
                  • cameronl
                    • 69
                    well i swapped my ex-demo model for a new one so it's all fine now
                    CaM
                    • Rags
                      • 185
                      There you go - which other company would be willing to do that ?
                      • nicholtl
                        • 539
                        Cool! Only now you have to set up all the calibrations again lol.
                        • cameronl
                          • 69
                          Hmmm!
                          yes, I wish i had saved those calibrations now
                          Still, my second C2 is now experiencing the odd audio dropout when playing through my DV88+p......about 2 a moive it seems.
                          Grrr!
                          CaM
                          • nicholtl
                            • 539
                            Hmm, since both your old C2 and this one are doing it when playing passages on DVD...and since your DVD player has changed from the 2900 to a DV88 (what is that btw?), maybe the glitch has to do with something linking the two?
                            • Rags
                              • 185
                              I have run various Arcam players with the C2 - DV88P, DV89 & DV79 - no audio dropouts whatsoever.
                              • cameronl
                                • 69
                                this all points to...
                                yeah, my dv88+p has never had audio dropouts on my other amps. I'm hoping it is something simple like a loose coxial cable.
                                thanks
                                CaM
                                • Jon SS
                                  • 75
                                  Damn, this just happened to me and my C2 is just over 1 year. When it switches off there is a clicking sound and the logo/light flashes as the unit seems to be trying to switch itself on.
                                  The first time I sent it back was because the sound kept switching off!
                                  I hate being without my C2
                                  • nicholtl
                                    • 539
                                    Gosh, I feel bad for you guys. I wonder why this is happening? But still, we gotta remember that even among the best of companies, a manufacturing defect is bound to happen sooner or later.
                                    If you hate being away from the C2 that much, you can come over and stay with me. I got room on the couch.
                                    • Rags
                                      • 185
                                      It's more of a design fault than a manufacturing defect.
                                      • cameronl
                                        • 69
                                        hi there all, i swapped my coixal cable for another one and after 3 movies i haven't heard any audio dropouts so it was hopefully my cable/connection.
                                        So in the end it probably worked out ok as I got to swap my faulty ex-dem model for a brand new one
                                        CaM
                                        • Jon SS
                                          • 75
                                          Just to update everybody, apparently the repair guys could not replicate the problem after 2 weeks of use. I guess it may have been a one off, hopefully it won't happen again. Should be getting it back this week.
                                          • _PM
                                            • 7
                                            Damn I think I've got the same problem over here. I've just send an email to the dutch distributor...
                                            • steven_braith
                                              RSX-1055 (F/W 2.30) keeps switching to standby
                                              by steven_braith
                                              Three weeks ago I upgraded (!?!) my firmware from 2.26 to 2.30 and since that day my RSX 1055 keeps on switching itself into standby.
                                              I have noticed that it tends to happen within the first 30 minutes of switching the unit on - so I'm thinking maybe something to do with it not having...
                                              23 March 2008, 20:50 Sunday
                                            • Club1820
                                              RSP-1068 Keeps Resetting to Default
                                              by Club1820
                                              I've had my 1068 for several years now. quite happy with it and have had no issues. On occasion since the beginning, it has reset itself to the default settings and then I have to go in and reset the Speaker Delay, Input Labels (DVD, TV, etc), Test Tone Volume, etc. Wasnt too much of a big deal...
                                              08 April 2013, 13:56 Monday
                                            • Pookie007
                                              Rotel Surround Processors - Video Switching
                                              by Pookie007
                                              The current Rotel Surround pre-amps don't appear to have HDMI inputs or outputs. Are you required to purchased an external scaler to get this feature? Has anyone heard if they plan on releasing something with HDMI included in the near future similar to what they did with the new receiver?
                                              16 August 2007, 23:02 Thursday
                                            • david cro
                                              Rotel RB-1080 power amp keeps blowing fuses, I have B&W Matrix 802 Series 3 speakers
                                              by david cro
                                              I recently bought a pair of B&W Matrix 802 Series 3 speakers on eBay and powered them with an Yamaha 3090 integrated amp. After a few months I decided to upgrade my Amplifier to Rotel Pre/Power and got RSP-1068, RMB-1075 and the RB-1080 (at Rotel's recommendation to power my B&Ws) I don't particularly...
                                              05 July 2005, 18:26 Tuesday
                                            • joeblizow
                                              1st post and of course...I NEED HELP...amp keeps blowing main fuse
                                              by joeblizow
                                              got a rb 980bx and it keeps blowing the main fuse in the back
                                              ac t4A FUSE Im assuming 250volt (thats what i used) not sure if need slow blow or fast is the correct one
                                              everytime I put in a fuse and turn on "pop"
                                              and I did search the forum before posting and it...
                                              13 August 2011, 20:19 Saturday
