To Much Power
  • Mike_Schmidt
    • 48
    To Much Power
    So I dumped my Pre Cyrus and Power amps for Parasounds JC2 and A21 power running into a set of Proac D28's. My room is small for the time being 10.5x12 I have french doors I open behind me which really helps and I do not hear much for reflection or boom for that matter. I have 10' ceilings so that might help as well.
    My question is can you have to much power, Iam not a volume junkie by any means but I do like so umph behind my music from time to time.
    First time caller, long time listener!
    Hi Mike, welcome to The Guide. :welcome:
    No. Having a lot of power won't damage your speakers unless you just completely overdrive them into failure (take a little care with the volume control). Having less than enough power can cause much more in the way of problems.
    Say, you didn't happen to play a pretty mean third-base at one time, did you?
    • Mike_Schmidt
      • 48
      No I could only wish, if I was my budget would be alot bigger Im just a correctional officer up in Canada doing my part. I just though since I havent received my shipment yet that it might be to much power for that room, but my Proac's are a lovely speaker and havent done me wrong. Im not worried about clipping my speakers just overpowering the room to be more specific.
      Thanks for the welcome
        Ah, well the only real possibility of having "too much power", (other than using it incorrectly like David said) is that you may have power that is going unused. As far as negative consequences goes, that's certainly a lot lower on the scale than other bad things you can do with your stuff.
        You always want to have at least a little bit of "extra power" though. If you're using your gear at full capacity, you run into clipping.
        • Mike_Schmidt
          • 48
          One more question since my CD player only has RCA's is it worth while putting a balanced interconnect between my pre and power amp if Im using Cardas Golden Reference RCA'S
            Oh, and Mike, I forgot to welcome you to the Guide and Club Parasound! :banana:
            • Neal_C
              Will new power cord make that much difference?
              by Neal_C
              Hello to everyone.
              I'm new to this forum and a new owner of Rotel equipment.
              I picked up the RMB-1075 about 2 weeks ago to power my Def. Techs. I read the reviews on the power cord and most people weren't impressed with it. I agree with them. Seems like a 1k component could come with a...
              12 February 2003, 19:34 Wednesday
            • espo
              Amplifier output wattage vs. power consumption
              by espo
              Many amplifier manufacturers rate their amplifiers at continuous multi-channel outputs that exceed the current inputs? ie Sunfire Signature Seven is rated 400 wpc x 7 = 2800watts, continuous all channels driven. The power consumption is rated at 15amp @ 120 volts which is 1800 watts without efficiency...
              09 November 2003, 19:45 Sunday
            • krips
              Behringer NU6000DSP iNUKE - How does it make rated power claims with 15A receptacle?
              by krips
              I'm wondering how power amps make this much power while running off what seems to be a standard power cord? This one in particular claims to put out 4400w at 4ohms with what appears to be a 15a cord running to it? To me this would require around 36 amps to do, so a 50A cord and #8 wire or better would...
              04 January 2016, 22:51 Monday
            • iceman
              Parasound Power Consumption
              by iceman
              I just received my electricity bill for the two months and it was outrageous. I jsut got my parasound setup which consists of the C1 and A51 about 2 months ago, which was previously a denon avr4802r. Now I dont use the parasound anymore than I used the denon, but is it true that my parasound could be...
              28 December 2003, 04:16 Sunday
            • lopezzz
              Which Rotel amp to power the Proac Studio 110 loudspeakers?
              by lopezzz
              Hello!
              After hearing to several loudspeakers I decided to go with new Proac's Studio 110.
              I was recommended to use the Rotel amplifier to drive these speakers. Last Saturday I did listen the Proacs with Rotel RA-1062 and found this combination, for my amateur understanding,...
              13 February 2006, 10:58 Monday
