Behringer NU6000DSP iNUKE - How does it make rated power claims with 15A receptacle?
  • krips
    • 264
    I'm wondering how power amps make this much power while running off what seems to be a standard power cord? This one in particular claims to put out 4400w at 4ohms with what appears to be a 15a cord running to it? To me this would require around 36 amps to do, so a 50A cord and #8 wire or better would be needed. Thanks .
    Sharp LC-42D64U
    TriTrix MTM (Sealed)
    manufactures (but not all) often take 'best case' scenarios when publishing specs.
    power ratings are often given for instantaneous performance (over a V short period time).
    the transformers & capacitors in amps also can allow for short bursts of power depending on the design.
    this is a V non-technical reply, others are welcome to go to further length in answering krips' question.
      • 16175
      There has to be sufficient energy storage in the capacitors in the powe supply to deliver that current- you're quite right, in that a normal 15 or 20A 115VAC line won't do it. This Class D amp uses a switch mode power supply, and energy storage could be done both at the output rails, and at the rectified bulk AC DC rail- and energy storage is proportional to the capacitance,but to the square of the voltage. That said, the 3 kW at 4 ohms is strictly a transient rating, based on the fact that music has a typical crest to average ratio of 6:1. So, the continuous power capability is likely 1/6 or less- in fact, if I could read the back panel illustration (at Sweetwater) a bit more clearly, I think it just says 625w. So Behringer may be working on a 10-1 ratio of peak to continuous power. Peak power will be set by the power supply voltage rails and how much energy the caps can store without sagging excessively. BTW, amps with a lot of rail sag don't usually sound very good. Note, this is really intended as a live performance PA amplifier, not for a home music system.
      • kevinm
        Adding 12v Trigger and silent fans to iNuke 6000DSP (along with other sweets mods)
        by kevinm
        Hi all,
        I almost posted this in my other thread, but thought maybe it could use its own. A few weeks ago I picked up an iNuke 6000DSP to run my LFE channel. These amps are amazing to run subs. The extra headroom for my drivers has added a very audible benefit to my system - and the DSP...
        25 December 2014, 23:06 Thursday
      • Clive
        Home Theater Glossary
        by Clive
        G'day Members. As part of our efforts to assist new and seasoned members I am starting this thread, to be used as a quick reference guide.
        I am sure that there will be some missing from this original list so in that case I will ask that members can post the words and there meaning/explanations...
        11 July 2005, 22:38 Monday
      • NMyTree
        Technical Question: Pre Amp into Power Amp
        by NMyTree
        Hi.
        I have question regarding output voltage of my Vincent Hybrid SA-T1 Pre Amp. Is that the right term?
        I'm wondering if my SA-T1 has enough or adequate juice to be matched up with my Butler TDB 2250 Hybrid Power amp?
        I don't know much about these...
        14 May 2006, 08:01 Sunday
      • espo
        Amplifier output wattage vs. power consumption
        by espo
        Many amplifier manufacturers rate their amplifiers at continuous multi-channel outputs that exceed the current inputs? ie Sunfire Signature Seven is rated 400 wpc x 7 = 2800watts, continuous all channels driven. The power consumption is rated at 15amp @ 120 volts which is 1800 watts without efficiency...
        09 November 2003, 19:45 Sunday
      • fjhuerta
        Zaph and the Energy C500
        by fjhuerta
        Zaph's blog has an interesting and amusing new entry here:
        http://www.zaphaudio.com/blog.html
        I read it with great interest, being a fan of Energy speakers. As a matter of fact, I think that not being able to afford a pair of Veritas was part of the reason I got into DIY...
        10 July 2009, 11:15 Friday
