JC-2 remote volume control?
  • Bob Stern
    • 7
    I would appreciate feedback from JC2 owners as to whether it is easy to make fine adjustments to the volume using the remote, or whether the adjustments tend to be too coarse or overshoot the intended change.
    (I love my JC-1's, but I'm inclined to buy a preamp with digital volume control to facilitate fine, repeatable volume adjustment.)
    Thanks!
  • Peter Nielsen
    • 1188
    I believe the JC2 has a servo controlled volume control (=VERY precise and 100% repeatable adjustment of analog potentiometer). Maybe a JC2 owner can back this up?!
    Peter
    • REOFan
      • 33
      Remote Requires a Finer Touch Than Mine
      Bob,
      I have owned the the JC 2 since July of 2007. I, too, own a pair of JC 1s. Peter is right about the volume control on the JC 2--it's precise.
      But to answer your question about the remote: I'm not as precise with the remote as I can be using the knob on the JC 2. Perhaps my touch is too heavy. It's not easy--for me--to make "fine" adjustments using the remote.
      However, the use of the remote is of less importance to me than the synergy of the JC 2 with the JC 1s. The match is exquisite--not to mention affordable--and produces sound--at least in my room with my equipment--that is immensely satisfying.
      Furthermore, the Mute botton is between the Volume Up and Volume Down bottons (in a vertical array). It's easy--at least for me--to accidently mute the sound when I intend to adjust the volume. It took some time to get the hang of it.
      But the remote was never a deal-breaker for me. It could be better (construction, feel, button array), but it could also be worse.
      The JC 2 is one hell of a preamp.
      I hope this helps.
      --Mark--
      • Karma
        Subwoofer Remote Volume Control Kit Construction Project
        by Karma
        HI All,
        I am wondering if there is any interest here in an article concerning construction of a subwoofer remote volume control kit? I have located a kit that is comprised of a motorized pot controlled by a PIC microcontroller. It is intended to be installed in receivers and preamps that lack...
        06 February 2006, 14:07 Monday
      • WallaceBW
        1066 Remote(RR-969) Question...
        by WallaceBW
        on the remote is there any easy way to make the volume up/down buttons of the video inputs control the Master Volume of the 1066?
        I suspect not so I Downloaded OmniRemoteā„¢ v1.171 Software for my palm (Which of course I left at the office). I will teach th palm the master volume frequency...
        19 January 2003, 10:32 Sunday
      • MountainA/V
        Broke RSX 1055 Remote-Can i control reciever with computer?
        by MountainA/V
        I am trying to avoid spending $400 on a remote, and i dont really like the stock remote anyway, so no need to buy another one (unless i have to)
        So two questions really, is there software i can buy to network my computer and reciever? If not, is there a remote out there that cost less...
        03 December 2007, 20:33 Monday
      • chanlon
        Volume Speed Control on 1069
        by chanlon
        Hi gang.
        Is it just me or is there no option to control the speed of the volume increments on the RSP-1069? I can't see the option in the setup menu.
        23 November 2008, 10:50 Sunday
      • Quantronics
        1098 Volume Knob not working after upgrade
        by Quantronics
        I've been a long time Rotel user w/ a 1098 processor and 1095 amp. I upgrade my 2.x firmware to the latest firmware. I also upgrade the EPROM using the directions on Rotel's website. I used all 4 EPROM upgrade 1, 2, 3 and 4 in that order. I then upgraded to the latest 4.x software. Everything went...
        30 March 2008, 20:20 Sunday
