Parasound P3/A23 with Subwoofer?
  • Audiognostic
    I'm building a 2.1 system from scratch and recently picked up an A23 Demo. I was looking to add a matched P3, when I realized it has no bass management. Does anyone on this forum have experience using this combo with a subwoofer? How did you set it up, and how did you like the results? From what I can tell, the options are:
    1. Run cable from P3 to powered subwoofer's crossover, run high pass subwoofer output to A23 and then to speakers.
    2. Use Y-splitters out of the p3 to the subwoofer and A23.
    3. Use balanced connectors from P3 to A23 and unbalanced from P3 to subwoofer.
    4. Use line out loop from A23 to subwoofer.
    None of these options seem ideal, as #1 requires long cable runs to and from where the subwoofer will be and #2-4 don't save my monitors from any of the bass load. Is this limitation enough reason to consider a different preamp? Any rumors about Parasound coming out with a 2 channel preamp with bass management a la the New Classic 2100?
    Hey, welcome to the Guide and Club Parasound! :banana: As for the question about the preamp, have you actually checked out the 2100? Or are you wanting to stay with an actual matched Halo set? (certainly don't blame you)
    The thing that comes to my mind is, if you run any option other than #1 you list above, as you mention you won't be using any sort of crossover to split a signal to go to either a speaker or the subwoofer. If you want to do it right, perhaps get an external crossover as well?
    • Audiognostic
      Thanks. The 2100 is a possibility, but I haven't seen any reviews, don't know if the sound quality is similar to the P3 and would prefer to match the look of the A23.
      If I do get a P3, any recommendations on external crossovers? I assume it gets placed after the preamp, splitting to the amp and powered sub. Would a passive crossover work in this setup?
      • HTLover
        Here is a pretty good review on the 2100 preamp.
        • thunderstorm77
          • 28
          I asked Parasound, they told me to connect it like this (I have speakers with integrated subs):
          Your speakers with integrated subs already have an appropriate crossover for the subs.
          The connection is easy:
          1. Connect the L and R balanced XLR output jacks on the P 3 to the balanced XLR input jacks on the A 23.
          2. Connect the L and R unbalanced RCA output jacks on the P 3 to the subwoofer line in jacks on the speakers.
          3. Adjust the sub level on the speakers.
          That’s all there is to it. You don’t need the built in crossover as the Model 2100 has (which is for subs which don’t have their own crossovers).
          This sounds ok to me. It doesn't take any load off my speakers, which I don't think I need.
          • Scarp
            Club Parasound F.A.Q. (Last Updated 21 Jan 2012)
            by Scarp
            (New information will be italicized to be easily identified)
            1. Introduction
            This is our FAQ for Club Parasound. We intend to add more as it becomes available or when we have time to update it.
            Please feel free...
            22 December 2003, 14:51 Monday
          • MichiganMike
            Parasound 2100
            by MichiganMike
            I have a Parasound 2100 Preamp with a Parasound A23 amp driving Salk SongTower speakers in a two channel system. This system does not sound as engaging for music as I had hoped. My home theater system which uses a Parasound C2 with a Parasound A21 amp and Von Schweikert VR4 JR is a significant improvement...
            16 January 2009, 13:29 Friday
          • TommyV
            Parasound Halo P3 vs Rotel RC-1090/1082 preamp
            by TommyV
            I am thinking about upgrading my stereo preamp. Right now I have a Parasound NC 2100 that I really like feature wise but if I was up upgrade, which would be a better replacement. I am already a fan of Rotel but am fast becoming a fan of Parasound as well. I have a Rotel 1050 amp but am considering upgrading...
            08 June 2010, 21:01 Tuesday
          • VictorHRS
            A23 or HCA1500A or RB1080?
            by VictorHRS
            Hi there Halo and Parasound Club members! This is just my second thread in this forum. I have appreciated it for a long time, but just as an observer. As you can see, I live in Brasil, which is not a good place to live if you like high quality audio. Everything is very expensive due to import taxes,...
            09 April 2005, 07:02 Saturday
          • MichiganMike
            Biwiring Parasound C2 to Parasound A23
            by MichiganMike
            Someone posted on Audiogon.com that they experienced improved sound when connecting both balanced and unbalanced cables to input a Parasound A21 amp. I have a Parasound C2 preamp processor normally connected to a Parasound A23 amp using balanced cables in a 2 channel system. Since I had a spare set...
            23 January 2010, 15:04 Saturday
