Opinions on sound quality between Rotel RB-1080 and RB-1070?
  • jam200
    • Jan 2009
    • 93
    Hello all,
    Any thoughts on sound quality differences between a Rotel RB-1080 and a RB-1070?
    I will use the amp to drive a pair of B&W 703s.
    Hi jam200,
    I'm an RB-1080 owner, but as I've never listened to an RB-1070 I can't comment on sound quality differences.
    However, if you occasionally listen to music at high volume then I would recommend the 1080 because of the extra headroom that the 1080 provides. It will lessen the possibility of your 703s clipping, particularly on bass-heavy tracks.
    • ray5
      • 444
      Hi jam200,
      WHat does clipping mean?
      • DrJRapp
        • Apr 2003
        • 1204
        First off, let me say that an amp clips not a speaker. An amp clips when it is unable to deliver the amount of current that the speaker demands at a given voltage input. In lay terms that means "isn't powerful enough".
        The term is called clipping since the tops and bottoms of the sine waves being generated appear to be clipped off ( flattened) when viewed on an osciliscope.
        Clipping causes a speakers voice coil to become hot and it may eventually burn out after being exposed to extensive "clipping". This is why we say that a smaller amp may do more harm to a speaker than one that is rated beyond the speakers power rating.
        In most cases clipping distorts the sound terribly so it becomes very obvious what is happening. If clipping is only momentary nothing may be heard. One can hear an amp that is approaching "clipping" because the sound becomes compressed.
        Many people prefer the sound of tube amps because they clip more gracefully than SS amps...it is less audible.
        Finally let me say...after having owned both that the 1070 is a very good amp, however, the 1080 is something special reaching well above the rest of the Rotel line in sound quality.
        Jerry Rappaport
        • Jovl
          • Jan 2009
          • 16
          I have owned the rb1070 and rb1090 ...................
          Good (rb1070), better (rb1080) , best (rb1090)
          Greeting Jovl
          My setup : http://forum.puresound.be/viewtopic.php?f=4&t=25
          Sorry for my English ops:
          • jam200
            • Jan 2009
            • 93
            Thanks for the comments. Most appreciated.
            JAM
            • bleeding ears
              RB1070 V's RB1080 any diff
              by bleeding ears
              Hi all,
              Can anyone tell me the difference soundwise between the RB1070 and the RB1080?
              At nearly double the price, does the RB1080 sound any better than the RB1070? (RB1080 = $1600 V's RB1070 =$900) Thats recommended full retail prices in Australia.
              30 August 2005, 10:16 Tuesday
            • Boombox
              2x RB1070 attacking Paradigm Studio 100s
              by Boombox
              I'm also new to the forum and must say..."Rotel or bust"...
              Ivhung is motivating me to ask this question. I am currently driving Boston VR2 (bi-wired @ 4ohm) with RC1070/RB1070 pair with Boston PV500 sub using the secong line-level outs of the pre-amp. It KILLS!!
              I want to get...
              28 October 2005, 01:40 Friday
            • wernert
              RB1080 Advice
              by wernert
              I am considering to complement my existing RMB1075 with a RB1080 which will be used to drive the front speakers. I demoed the RB1070 a while ago, but it was not much an improvement on the existing RMB1075 in 2 channel mode. The RB1080 is definitely the one for me. After reading several articles in...
              14 December 2004, 09:06 Tuesday
            • kitjv
              RB1080/RC1082 - I Need a Bit of Guidance
              by kitjv
              I had the opportunity yesterday to audition a pair of Paradigm Studio 100s with the Rotel RC1070/RB1070 preamp & power amp combination. My ears were very pleased. However, I am curious about the audible difference that the Rotel RC1082/RB1080 would make with these same speakers. Or maybe going with...
              13 December 2007, 21:56 Thursday
            • bleeding ears
              2 x RB1070 Bridged V's 1 x RB 1080 ?
              by bleeding ears
              Hi again guys, looks like I am going to have some time on my hands waiting for my preamp to get fixed so now I am pondering my next purchase.
              I am considering using 2 RB1070 amps bridged to power my front speakers.
              That should produce about 330 wattts per channel.
              16 November 2005, 04:11 Wednesday
