I am running Bryston 7B ST's with N801's. The Bryston's have 2 settings, series or parallel.
The Series mode has a higher voltage swing and is (per the manual) appropriate for loads between 3 and 8 ohms.
The Parallel mode has more current available and is for loads of 1 to 3 ohms.
From whay I have read, the B&W's dip to about 3 ohms, so it seems that I should be running Series.
What have others here experianced?
Thanks.
Thanks.
I am considering building an WWMT, using two 8'' or 10'',4 ohm woofers wired in series to give 8 ohms nominal. Bass performance is very important to me(not boomy,but tight,accurate and punchy). :roll: Can anyone give me some serious reasons why this will not be satisfactory,compared to 8 ohm woofers...
