Cooling Fan?
  • wettou
    • 3398
    Cooling Fan?
    Cooling Fan?
    What about them?
    Are you asking if they work? How to arrange them? How noisy are they? What kind to get? A little more direction will let us answer better.
    • krips
      • 264
      Cooling fan! Use the largest that you can for the application at lower RPM I would say. That's my general recommendation to the question :P.
      Sharp LC-42D64U
      TriTrix MTM (Sealed)
        Press Release today on Zbreeze cooling fan
        I got this press release today on the Zbreeze: Found at www.gspr.com....
        02 March 2006, 07:23 Thursday
      • Snap
        Plasma Screen /Cooling Issues
        by Snap
        I thought that this should be in the mission possible area due to the complications of the issue.
        Overview: Plasma Cooling Issue
        The framers kind of messed up on some things in my new house.
        I have 20-foot ceilings in my living room in my new house. The...
        12 July 2006, 08:55 Wednesday
      • Angioguy
        Cooling Fan Recommendation?
        by Angioguy
        Just thought someone out there might be able to suggest a good company that makes small clip-on or wall-mountable, ultra-quiet cooling fans for placement inside an enclosed rack system. I would prefer an AC powered unit, and if possible, one that activates by an internal thermostat or one that is...
        02 April 2006, 21:51 Sunday
      • Wedge
        RSX 1067 Cooling Fan: "On-n-off-n-on-n-off-n-on-n-off"
        by Wedge
        I'm wonderfully satisfied with my Rotel RSX 1067 and have enjoyed it for close to 2 years. However, today I noticed something new. After an extended listening to a DVD in 7-channel stereo--the fan started and stopped, repeatedly--as if it just couldn't get started. It'd run for 1/2-1 second; turn...
        05 January 2008, 19:32 Saturday
      • Dotay
        DIY variable speed quiet fan kit
        by Dotay
        When I was at DarrenE's house for our subwoofer test he showed me a variable speed fan he bought on ebay. I'd like to try and Klone :B this kit and I think it might bennefit those of us who are using pro-amps to power subs and the like to make the process public. The problem is I don't know exactly...
        22 March 2006, 11:17 Wednesday
