Wall Plate - HDMI/CAT5/Power
  • Nolan B
    • 1792
    Can anyone suggest a wall plate that has power, HDMI and CAT5? Id like to have one installed behind a plasma im installing. If there isnt one which has all 3, perhaps 2 separate ones? Not sure how it would normally be done.
  • Kevin D
    • 4601
    Well, Panamax makes what you want, but no HDMI module yet. Double gang plate with a recessed surge protector and a slot for a 'module'. You can put a decora plate in there and it comes with a 2-port keystone adapter. You could put a CAT5 keystone in and run the HDMI out the other hole.
    Datacomm has something similar, but it's just a recessed plug (no surge) and a shaped plastic internal spout to run the cables out of. You can also get a matching set if the equipment is going below the TV. Power-in and up sloping spout on the bottom, power-out and down sloping spout behind the TV.
    That said, I would be careful trying to do an HDMI wall plate. Most are a simple female to female coupler that can cause problems. In addition, you will have a hard time turning the HDMI cable in the wall to hit the plate straight on and also having the HDMI cable coming straight out into the back of the TV.
    There are a few companies that have right-angle HDMI plates. Pigtail in the wall so the HDMI cable can come straight down or up into the plug and a 90 degree block on the front so the wall to TV cable can remain parallel to the wall.
    So I would probably look at just doing the panamax or datacomm units, but having the HDMI run straight out of the wall to the TV.
    Kevin D.
    • Nolan B
      • 1792
      Thanks Kevin,
      You re right in that its probably easiest to fun an HDMI cable rather then worry about the wall plate. My HT rack will be about 10 feet away from the plasma and just want the cables in the wall hidden.
      Ideally Id like a power cord (male on one end and female the other) so i can plug the plasma into my RLC 1040. I guess I could just run a power cable that is rated to run in wall?
      Come to think of it who needs a wall plate at all..i might as well just run the cables all through the wall from one end to the other.
      My only other concern i guess is that I will have to go between studs. as the rack is off to the side and not straight down. Do you know if metal studs typically have holes or cut outs in them for running a cable through?
      • Kevin D
        • 4601
        Unless otherwise requested, none of out installs have a wall plate. You might get a trim-ring and plate with a hole in it, but generally a small hole is all we do.
        Metal studs generally have ovals cut into them. They will be sharp, so protect the wires and be careful. Hopefully they will all be lined up. If so, you should be able to get through about 3 or 4 studs with a fiberglass rod.
        Worse case is to pull the kick molding off the bottom and cut the sheetrock behind it. Runs the wires along the bottom and then replace the sheetrock & molding. If you cut it right, all you will need is is some nails, caulk, and paint.
        Kevin D.
        • Blindamood
          • Sep 2003
          • 900
          I'd recommend a simple entrance/exit wall plate, such as these:
          I used two of these in my bedroom - one low on the wall (behind a dresser), and one behind the lcd mounted on the wall. Simple and effective.
          Brad
          • HedgeHog
            • 241
            These guys are in Canada and cheap. http://www.infinitecables.com/av_wall-plates.html
            I built mine from their inventory.
            -Hedwig
            • Hammie
              • 304
              Personally, I would not run power and HDMI/Ethernet in the same wall cavity. I have my power on one side of a stud and my HDMI and Ethernet in the next one over.
              I would then use the Decora plates for the HDMI and Ethernet. I think Monoprice.com has them for a very reasonable price.
              Panasonic TC-P65VT30
              Next Upgrade: Cables
              • dookie
                here we go... (tons o' in-wall wiring ?'s)
                by dookie
                first of many questions...any/all info much appreciated. here's the deal:
                the stud walls in the basement just went up and i've been reading a lot! with access to all the 1st floor low voltage wiring from below (it's a freakin' mess) and cat5 wiring experience/tools from work, i figure...
                19 May 2005, 18:32 Thursday
              • tpremo55
                Wall-Mounting LCD Help
                by tpremo55
                I've just purchased our first flat panel TV - Samsung LN52A750 - I'm not exactly what you'd call an early-adopter. I'm looking for some recommendations in a couple of areas and have searched both this and PE with little success in finding what I need. Maybe I'm searching the wrong keywords as I can't...
                29 November 2008, 14:19 Saturday
                How I've added HDMI 1.3 high bitrate audio decoding to my Parasound C1
                Quite a thread title, I guess. Perhaps I should subtitle it, "or how I learned to stop worrying and love the bomb... I mean, theater."
                As the title says, I've added HDMI 1.3 audio decoding to my home theater, centered around the Parasound C1 home theater controller. As...
                08 April 2008, 03:28 Tuesday
              • brian.hillier
                Thought on impact of HDMI on receiver design
                by brian.hillier
                Hey all,
                I am interested in your opinions on what impact, if any, the new HMDI specs will have on receiver design.
                Granted that Dolby HD and other new audio codecs have not yet been included in any of the new receivers I am looking at, but the question has been posed to...
                17 January 2006, 11:33 Tuesday
              • freon
                Wireing needed for Front wall sub
                by freon
                I am running wires for front wall. I have not purchased my sub yet, actually I may even try one of the sonotube designs I have seen in here.
                I am wondering what wires I would run to the front right and left corner of my front wall to accomodate any type of sub I may buy or build.
                13 March 2005, 10:08 Sunday
