Samsung Blu-ray(BD-P2550) vs Pioneer Blu-ray(BDP-51FD)
  • Armbender
    • 265
    any thoughts between them or a better recomendation...looking to get one in the next couple weeks...
    Samsung UN60C6300 | Primare SP32 | Primare A30.7 | Oppo BDP-103 | PS Audio Quintet | AppleTV | ELAC 247 Black Edition | ELAC CC 241 Black Edition | B&W DM 600 S3 | SVS PC 13 Ultra | Straight Wire Virtuoso | Harmonic Technology Pro 9's | Black Sands Power Cords
    I don't know about a better recommendation, but I'm really happy with my Pioneer BDP-05FD. I know it's a good bit more than the -51FD, however the images it outputs to my HD plasma (50" Elite) look better to me than any of those I've seen on friend's and family's HD systems.
    • Armbender
      • 265
      i definately like the looks of the Elite..a little priceier but i want to be happy with it for sure..
      • planitismetal
        • 212
        I got Samsung BD-P2500 and it is nice... Not anything special, but it is quikly and working with silence... Also I like that it hasn't got many buttons on the front...
        • Armbender
          • 265
          it definately look sleek..very sharp..but does it live up to the elite blu ray
          • planitismetal
            • 212
            Look, the menu is very simple, sometimes I think that it hasn't got many functions... It is my first BD and I didn't have any comparisons, so... It's up to you... The only thing that I'm sure is that it is quiet and fast...I have it only a month... :huh:
            • Armbender
              • 265
              thanks for your review...
              • Jcake5
                • 6
                BD-P2550 Has the ESS Saber DAC
                If you are into using the 7-channel analog outputs from the player then you might want to consider the Samsung. It uses the ESS Saber DAC which is setting the audio boys on fire for sound quality. I have the Samsung and on my system I can hear the difference between using 7-channel analog outputs vs. the digital outputs. The only drawback is if playing 2-channel audio there is no LFE out to drive a subwoofer so your fronts must be able to do all of the bass frequencies.
                Regards, Eric
                • Armbender
                  • 265
                  Regards, Eric
                  thanks for the info..i actually never use the 7ch analog...
                  right now im leaning towards the pioneer elite...
                  • Armbender
                    • 265
                    is the 51fd a big difference form the elite 05fd?...i mean to justify the price increase
                    i am for the record only using a 1080i tv..the samsung dlp5685w
                    • Pookie007
                      Pioneer BDP-51FD Blu-Ray
                      by Pookie007
                      Has anyone used the pioneer BDP-51FD? When I read the reviews they seem favorable other than the price. Now the price has dropped to $350, so I am considering this as a bedroom Blu-Ray player. I have a 50" Pioneer Kuro in that room. The audio runs through the tv since my wife refuses to let...
                      24 January 2009, 02:14 Saturday
                    • BW4me
                      Pioneer 51FD vs 320FD
                      by BW4me
                      I'm deciding between these two models (51fd and 320fd) since I can get either new in box at $199.
                      51 uses Wolfson DACs and 320 uses BurrBrown DACs. I'll connect to my AVR using 5.1 analog outputs. I'm just wondering if there much of a difference between the two units for audio output?...
                      31 August 2009, 16:28 Monday
                    • grit
                      Samsung LED - makes movies look like daytime soaps
                      by grit
                      I recently bought a 46" Samsung 8000 LED LCD tv. I previously watched a 3 year old 42" Pioneer Elite plasma.
                      I'm very impressed with the Samsung, save for two major problems: light leakage and a wierd video effect that can't be disabled. All HD sources look like your watching...
                      27 July 2009, 12:21 Monday
                    • crytklmass
                      samsung stumped? cant view Max Payne
                      by crytklmass
                      I own a Samsung model 1500. I tried to watch max payne and it kept freezing or the sound stopped. So, I visited http://www.blu-raydisc.com/en/Technical/Updates.html. this is there statement for my model:
                      While a few Profile 1.1 players—Samsung’s BD-P1500, for example—can be upgraded to...
                      17 February 2009, 23:06 Tuesday
                    • cestarr
                      RDV-1040 and Pioneer Plasma 5040HD Problem
                      by cestarr
                      When using the component cables only there is no red in the picture (all blue and yellow). With S-Video only the picture is normal. I've tried other component cables but the problem persists. A samsung progressive scan dvd player was able to produce a normal picture and colors in progressive mode with...
                      23 July 2004, 11:41 Friday
