I've owned a Pioneer DV-05 for almost 2 years and it has never given me any problems whatsoever. No lip sync, no prolonged layer changes, no nothing. Lately, it has started to stutter and skip with the audio portions of BOTH DVDs and CDs. This skipping usually occurs after about 1.5 Hrs of continuous use. If I pause and then restart the unit, it continues to stutter. If I stop the playback, open/close the drawer and then start it, sometimes it begins to stutter again. If I turn the DV-05 off, then back on again, it plays perfectly for the rest of the DVD or CD. Is this unit about to bite the dust? Could the problem be due to a dirty lens? Is there anything I can do to inexpensively fix this problem?
Thank you for your help and suggestions!
Take Care,
merc
Take Care,
merc
