Survey says:
VCRs, do you use them? are they in the garage collecting dust? Destined to become a boat anchor on that yatch you've always wanted? (Or fishing dingy)
If they are in your system and you don't use it, is it actually hooked up?
If you use it, how often do you use it, and for what? Do you actually watch what you record, or is it some bizarre ritual that started years ago, and your just afraid to stop?
I'm curious. Like all my surveys, I reserve my comments for later.
Lex
Cable Guy DVD Collection
Lex
I do record the odd show here and there but not very often since with the timeshifting on the dish if I miss a show I'll just wait a little bit and pick it up on another timezone.
.....anyway here is always a place to use some quality time until the NeoCitron takes effect :?
ops: The one that gets used the most is in the den.
