I am running out of rack space and was wondering if I can replace the approx 1/2 inch feet in a couple of my parasound components. Any thoughts? Are replacement feet (ie, 1/8 or 1/4 inch) sold anywhere?
Reducing "feet height" for Parasound components?
Ricky,
You can buy the self-adhesive rubber pads at Wal-Mart, Home Depot etc.. If that's what your looking for and they come in all different sizes.
I would wonder if that wouldn't increase the amount of heat generated buy your amps though. You be cutting down on the amount of air allowed to flow threw or around your amps, so I'd be a little cautious with packing them tightly together.- Bottom
Thanks for the info, I will look for those rubber pads. I would like my parasound changer to fit on top of the 806 amp, and need to shave 1/4inch off their combined heights. The 806 does not run nearly as hot as my two 2200IIs, which have their own shelves and ~ 0.70 inches of top ventilation in my open rack.
So I would remove the 1/2inch feet from the 806 and put on 1/8 - 1/4inch rubber pads? There would still be the 1/2inch of top ventitation from the changer's feet.- Bottom
These are probably too big but you might want to contact the vendor for exact measurements: http://www.crtcinema.com/store/?page...0ae221c454baf8
This one is 1/2" :
-Sili- Bottom
Ricky- What Parasound changer is this that you have? (CD I assume and not DVD???) How do you find it to work for quality output?
Luke: "Hey, I'm not such a bad pilot myself, you know"
- Pleasantville- Bottom
Sili,
Thanks for the links. I'll call the first vendor. Not sure what the 2nd link means though.
Chris,
I have the cdc1500 5disc changer, that has the Adam upgrade --- which adds the balanced, AES/EBU digital output. The onboard dacs are actually quite good. I have bought all my Parasound gear used, so haven't really interfaced with Parasound much yet. I really like their products.- Bottom
Whoops! I'm not sure how that 2nd link got in there. Sorry. Do a search at www.partsexpress.com for isolation. I think that's how I found it. They have 3 or 4 different "feet" at various sizes. They're just plain black though.
-Sili- Bottom
by shazbotHello
I am not sure if theis is the best forum for my question but here goes
I have severel spiked feet (not sure that they are called that) small upsidedown pyramides
I have placed them underneath my DVD Player and record player
Is this worth...-
Channel: Audio Hideout
by orangebullI am moving to a home with tile floors in the room where my 703s will be located. They will be powered by a Rotel RB-1090 and the room is large (24'x27' by 16' tall)
Does it make a difference how the speakers sit on the floor?
My question is should they sit directly on...-
Channel: Club B & W Speakers
by james_dmiAfter hearing that people are experiencing extra base definition by using spikes I'm thinking of doing the same. This will involve swapping round the feet on my 802D’s from the soft rubber end to the spikes. These will then be seated in spike shoes so as not to damage my flooring.
With...-
by nismoronI've got some Aria5's (dual Focal 5's and Focal kevlar tweeter) that I built a few years bach that I was unhappy with the sound and shelved them after little use. I want to get them back out and combine them with some Focal 10's to create some large floorstanders. Problem is this... The upper vocals...-
Channel: Mission Possible DIY
by AshHi guys, as you know i just bought a pair of pre-owned N800 and I'm starting to find some problems with them.
It seems the on one of the speakers the rubber seal surrounding the FST drive is tucked under the FST drive at a certain area, thus exposing a white surface that comes behind...-
- Loading...
- No more items.
