Black & White vs. Color
  • John Holmes
    • 2707
    Last night, my wife and I watched The Creature from the Black Lagoon via cable. The picture was so good that I felt like I was in the 60's (7 or 8 yrs of age) seeing it for the first time! I swear it looked as good as I remember first seeing it.
    Anyway, this lead me to wonder "why" to dvd issues. Like, If a film this old can look this good on cable, Why do great releases from the 70's and 80's that are in color not hold up the same? I would think that on the dvd this would not be a problem in most cases.
    Just for instance: The Wrath of Khan. Though better than it's vhs brother doesn't hold a candle to my recent viewing of Creature from the Black Lagoon.
    Any thoughts?
    • 16170
    Black and white is a snap compared to color for working with old prints. I've got a recent DVD issue of an old Bridgette Bardot film, B&W, 16X9 enhanced widescreen, looks great. Better than B&W over cable, for sure. Problems with color film are legion; the dyes deteriorate, cleaning steps they use when finishing internegatives strip different parts of the emulsion (and different colors) at different rates, and finding an old print that is clean, or restoration worthy, is much harder. Remember, a black and white picture can be represented fairly well with a 256 bit gray scale (only 256 distinct values), whereas equivalent color reproduction accuracy requires 16.7 million colors to be accurately reproduced.
    • KennyG
      • Sep 2000
      • 746
      Just so you know, the DVD of Creature looks very good also, I would think even better than on cable.
      • John Holmes
        • 2707
        Jonmarsh,
        Okay. I can live with that
        KennyG
        Thanks for the tip!
        • DUCKY
          Why no color running DVD through RSX-1056?
          by DUCKY
          Guys,
          I was running a component cable directly from my RDV-1060 to my Panny projector. Yesterday I tried to hook up the video out to my RSX-1056 using s-video (I had a good s-cable handy and no second component cable) then use the component monitor out to go to the Panny projector. Accordding...
          19 December 2005, 03:29 Monday
        • gtopaul
          No color after DVD Player Swap
          by gtopaul
          My home theater setup has a Sharp Aquus 1080 flat screen hooked up to a B&K AVR317 receiver and Rotel DV-1092 DVD Player. I was using the S-Video connection between all the components since the B&K doesn't have HDMI. Everything was working fine until I change the DVD player to an Arcam DV-79...
          16 June 2011, 16:49 Thursday
          Who wants Halo gear in black? :)
          This has been asked about here in Club Parasound ever since Halo gear was first introduced 10 years ago. Aaaaaand... you got it! Parasound continues to listen to their customers, here and elsewhere.
          Hot off the press, formally released today. I've been keeping this under my hat for...
          24 September 2012, 21:16 Monday
        • focus
          Picture gets Black & White with up conversion with RSX 1067
          by focus
          Hello need some help with this problem! The picture gets black & white, for a couple of seconds, when using s-video signal from my digital-tv-box into the receiver. I use the component output signal to my projector (sanyo z3). This only happens when watching digital tv. The is no problem using...
          20 August 2006, 08:12 Sunday
        • Razvan
          Black background?
          by Razvan
          Has anybody tried to select black background in the Superimpose section of the OSD Setup sub-menu? When Black is selected the OSD menu is supposed to be "displayed on a black background at all times". I tried that on my unit but it doesn't seem to work i.e. I can't change the background color...
          10 May 2002, 00:51 Friday
