Minimum wattage for speakers
  • John Holmes
    • 2707
    When I listen to music or movies, there seems to be a certain volume level where the speakers come to life. When the pluck of a guitar or gunshot becomes involving and not just heard.
    Is this the point where the speaker is getting the minimum watts it needs to "turn on" so to speak? If so, where does current play in?
    • 16478
    I'd say it has to do more with SPL then wattage...of course they're related but given the different kinds of amps you can use (tube vs solid state) I'd venture to guess that it has to do with energizing the room
    • John Holmes
      • 2707
      That maybe, however, with so many audiophile type tube amps that only put out 8 watts or so, how can they achieve this with a speaker which states it requires 25watts min?
        • 16209
        They can't, John. The SET amps are designed to be used with speakers which are in the 93-96 dB/watt sensitivity range, which does limit the field of application.
        The phenomena you're experiencing is based on human hearing and that old familiar Flether-Munson loudness curve.
        For playback to have the same perceived loudness and dynamic constrast as the original performance, it should be at close to the same SPL- not louder, not softer.
        This is actaully a problem for high accuracy speaker systems, like dynamic diple speakers, which don't interact with a room in a way to create the perception of extra bass. This extra bass makes music sound a little louder than it is- hence, the typical extra boom or thud of many speakers is a type of loudness compensation, just as the bass boost switch common on old recievers and amplifiers did the same thing. (Am I dating myself a bit, here?
        Many reviewers of Linkwits's dipole systems, such as the Vivaldi or Beethoven, have commented on how they seemed to need to be turned up a little more than a "standard" box system to come alive- this is because they minimize resonance and room interaction in the bottom end. (Of course, they also sound more lifelike and natural, and much more detailed, once you reduce the peaks and dips from room interaction. The latter can be managed with correct room placement, but most folks don't or won't do it, because they don't like where the speakers wind up). :roll:
        So, in summary, it's your ears, and the ear-brain interface. Not the speakers, really- their linearity at low levels is good, much better than at high levels, in fact!
        • John Holmes
          • 2707
          Thanks Jon,
          It now makes sense to me. I was unable to put my finger on it before.
          I guess here is where the real issue begins. This has been something I have asked myself a thousand times. With music and movies, who really knows what the artist or director's intent was at it's creation. I'm sure the overall level as well as specific passages, were designed to be a far cry different than what we play them back at in many cases.
          As for room interaction and placement, I know how critcal it is. After you gave me the heads up about speaker placemant referenced at the Cardes site (a few months ago), I have played with placemant quite a bit. With my room now being almost square, it became more important to get the speakers placed correctly. My speakers are very accurate in tonal quality (I like it that way). And I always run my sub since they roll off at 80hz. But, I do have to get them up a little in volume, to give me that tactile feel of the instruments. Which surprises me with my room being so small and having more than enough power.
          I guess I should feel as you about "dating yourself". I recall when having it (Bass Boost) was a must have in my youth. ops:
          • Brandon B
            • Jun 2001
            • 2189
            How come there is no word for dating one's self? There's one for having sex with yourself. You'd think there'd have to be at least one date first.
            BB
            • Kevin P
              • 10812
              Well, I suppose since you have to live with yourself... :?
              And yes, I've had (and still have) receivers with the "loudness" / "bass" button. And I admit to having used it in my youth. Heck, I even had a graphic equalizer! ops:
              KJP
              My HT Site
              • Burke Strickland
                • Sep 2001
                • 3159
                So the rest of you won't have to go through the same wild goose chase I did earlier today, the name is "Cardas" -- actually George Cardas -- and the information he gives is VERY useful -- I followed the formula for planar speakers quoted here (emphasis added for the planar formula-- and box speaker formulas left in the quote since most of you will be more interested in those): http://www.soundstage.com/audiohell/audiohell200111.htm
                RW x .276 = Distance from the center of the woofer face to the side walls
                RW x .447 = Distance from the center of the woofer face to the wall behind the speaker
                This applies to box speakers only. Dipole or panel speakers cancel side waves, so a multiplier of .618 x the ceiling height will give you the distance from the rear wall.
                and got an immediate improvement in my Magnepan's soundstage -- even though my "intuitive" trial-and-error placement was just a couple of inches away from the "formula-specified" position. (It wasn't all that "bad" before, but following the formula noticeably increased the "sweet spot" to a "sweet area"(tm) and widened the sound stage overall).
                The full article with a lot of supplemental material for various room configurations can be read here: http://www.cardas.com/cgi-bin/main_c...ing=Room+Setup
                Note that he refers to "rear wall" as the wall behind the main left and right stereo speakers -- many of us with a home theater orientation refer to that as the "front wall". You sure don't want to use his measurements to pull your speakers too far toward the wall behind where you sit. :>)
                Burke
                • John Holmes
                  • 2707
                  Thank you Burke for keeping me honest! 8)
                  Yes, there is a ton of useful info there. It's a great read for novice and pro a like.
                  • bleeding ears
                    Why do speakers have a max watt rating
                    by bleeding ears
                    Whilst pondering which amplifier and which output wattage would best suit my speakers, I became a little confused about the whole amp/speaker wattage compatibility issue.
                    Eg , if speakers can handle wattages well above the manufacturers specified maximum rating, why do they specify...
                    08 February 2006, 08:49 Wednesday
                  • espo
                    Amplifier output wattage vs. power consumption
                    by espo
                    Many amplifier manufacturers rate their amplifiers at continuous multi-channel outputs that exceed the current inputs? ie Sunfire Signature Seven is rated 400 wpc x 7 = 2800watts, continuous all channels driven. The power consumption is rated at 15amp @ 120 volts which is 1800 watts without efficiency...
                    09 November 2003, 19:45 Sunday
                  • sbank
                    Amp wattage question.
                    by sbank
                    Hi All, I have a question on wattage for the RB-1080 amp. I know a lot of you keep your amp on all the time, and some people turn it on and off. I sure don't want to bring up that discussion again on which is better, but I do have a question from a fiscal standpoint.
                    The RB-1080 (I...
                    22 June 2004, 11:19 Tuesday
                  • Sahren7
                    OT - Can a 7.1 system use different wattage amps?
                    by Sahren7
                    Newb questions, yes, but I simply do not know. I recently moved to separates. I have acquired a used processor (AV7005) and funds dictate that the amps will be acquired over time on the used market. As such I might end up with different brands having different wattage. I was thinking of getting...
                    07 December 2016, 23:56 Wednesday
                  • specialized
                    Rotel RB-1070 Minimum Impedance in MONO Mode
                    by specialized
                    Hi there.. I'm ordering B&W 803S speakers, powered by Rotel 1080.
                    As Pre/Pro i'm using Denon 3808 reciever, so for the front speakers power make RB-1080 (which is very nice and for the price is best at my opinion).
                    I'm thinking how to power B&W HTM3s center speaker and...
                    26 August 2008, 16:03 Tuesday
