Line Doublers and Scalers
  • GregoriusM
    • Oct 2000
    • 2755
    I think I have an idea about the difference between line doublers (used in progressive DVD players and some TVs - HDTVs I think) and scalers.
    But, how much do I need to spend to get a doubler or scaler to put between my Digital Cable Receiver, VCR, DVD player and my TV.
    Also, do I need an HDTV to be able to use an external doubler/scaler?
    I have a Panasonic 27" GAOO TV, with 750 lines of resolution, which brings me to another question. Is that horizontal or vertical resolution. What is usually quoted?
    I'm tired of the "jitter" from regular cable, and have seen HDTV's of up to 60" that are greatly improved with internal line doublers.
    Any information would be greatly appreciated. I don't want to upgrade my TV until HDTV comes down in price and there is more content on the tube.
    Thanks!
    ... Greg :-)
    Gregor
  • Gordon Moore
    • Feb 2002
    • 3188
    Zero, your TV doesn't support the frequency nor the resolution to handle line doubled or HDTV material.
    Yes or at least HDTV ready or a pc monitor or a projector
    Horizontal...marketing...it sounds better
    The most inexpensive and versatile scaler, progressive scan dvd player, HDTV tuner,TIVO,gaming machine,MP3/CD player that you could purchase and/or assemble yourself is a PC (HTPC). It's easier than you think.
    "A RONSTER!"
      • 16202
      Scalers and doublers are of most use with graphics grade CRT projectors (XGA or better) and digital projectors that support direct pixel mapping, but also can be useful with high res direct view presentation monitors.
      By far, the best value in a scaler/doubler would be an HTPC, as Gordon points out. For external NTSC video sources, DScaler and a compatible video capture card are the way to go.
      For video output and DVD playback, a Radeon or Geforce card will provide excellent playback with the better software players (Ravisent Cinemaster, Power DVD 4, Theater Tek); the best I've seen so far is with a Radeon 7200 or 7500 type card (the 8500 has hardware/driver issues with gamma adjustment which are still unresolved by ATI). The Geforce series doesn't have quite the same level of shadow detail and color detail, (possibly due to 8bit verus 10bit DAC, and other details in intermediate processing), but still is quite good.
      A PC scaler can't create detail that isn't their, but like oversampling of CD digital, it can interpolate and smooth to higher resolution playback device with excellent results, especially on quality DVD's like the Superbit titles.
      • rlabarge
        Line Doublers & 480P(30) Content
        by rlabarge
        I have been trying to push the DVD-Video format to its limit as far as video quality is concerned. Many people know that DVD-Video supports progressive scan video from film - called 480P(24). However DVD also supports progressive scan video at a higher frame rate - called 480P(30).
        I...
        19 April 2002, 09:52 Friday
      • Sonnie Parker
        ADS Tech HDUP-1500 HDTV Upconverter
        by Sonnie Parker
        I don't know squat about scalers and doublers but this looks like it might could do some good, especially with cable and satellite sources. Price sounds very reasonable at ~$600. Expected release date in September 2003.
        Is it possible?
        Enhance your Home...
        19 August 2003, 12:11 Tuesday
      • greggz
        Rotel Announces RVE-1060 Video Scaler
        by greggz
        North Reading, MA—January 2007—Rotel, well-known throughout the world as an affordable high-end manufacturer of components for music and home-theater audio-video systems, has introduced the RVE-1060, 1080i video scaler, which seamlessly brings together analog and digital video sources.
        10 January 2007, 07:15 Wednesday
        When is HDTV Not HDTV? Much more often than you think...
        One of the things I've noticed looking at a lot of name brand HDTVs in stores from CostCo to Best Buy is that the overal resolution I see is no where similar to what I get at home, often even with SD material. In the latter case, it looks like scaling artifact and MPEG issues, but not the kinds I'm...
        27 April 2006, 14:13 Thursday
      • Adz
        Scalers/Video Processor Question
        by Adz
        Does a scaler/video processor like the IScan HD+ or a Lumagen offer much better picture improvements for DVD Video versus just using an upconversion DVD player to a projector (or sending an analog component signal from a DVD player to an upconverting projector)? I noticed that projector reviewers always...
        13 April 2005, 05:34 Wednesday
