Recommendation For Amp Fan
  • comeup
    • 356
    My amp gets hot after being on for 30 minutes or so and its in a open area. I can't seem to find something I like. I want something that won't be visible and possibly with a 12 volt trigger that will lay flat on top of the amp. Any help would be appreciated. Thanks
    Blake
  • BeeBop
    Using 12 volt trigger
    by BeeBop
    I have an external amp I would like to use with my RX1050 stereo receiver - using the RX1050 as a pre-amp. I am using the pre-out to connect it to the amp and it is working well. However I cannot get the 12 volt trigger to work. Does anyone know what sort of plug the 12 volt trigger out requires? My...
    13 May 2004, 05:32 Thursday
    Press Release today on Zbreeze cooling fan
    I got this press release today on the Zbreeze: Found at www.gspr.com....
    02 March 2006, 07:23 Thursday
  • BKSinAZ
    Turns out that they did not sell me a dead AMP. Just got a call from them today.....
    by BKSinAZ
    Turns out that they did not sell me a dead RMB-1095 AMP. Just got a call from them today. They stated that the 12 volt toggle switch was in the wrong position.
    My question.......with out a 12 volt line in the amp not work in which position ? What about with a 12 volt line in? I am c...
    09 January 2004, 15:57 Friday
  • scarpi
    Issue with B&K Power Amp?
    by scarpi
    I have a B&K 200.5 series two power amp. For all you B&K owners out there I have a question. My amp is plugged into its own dedicated 20 amp line. I usually use my preamp (Marantz AV 8801) to turn on my amp from standby via a 12 volt trigger. This always works fine with no problems at all. But...
    09 June 2013, 12:59 Sunday
  • Jerm357
    Is 1 volt low enuff for a cleanbox?
    by Jerm357
    How much signal is my Pro amp missing out on if my receiver Pre out is only sending out a 1v unbalanced signal. Is 1 volt low enuff to justify the purchase of an art cleanbox? I am using an Onkyo receiver (TX-SR600) and an ep1500 pro amp. I just think the amp is not getting all the signal it needs...
    26 September 2006, 16:13 Tuesday
