Just wondering, if I happenned to have a projector, I'd need to make a decision as to which cable will be the short run. It' either the video, say under 3' and then the audio connector would be like 9', or vice versa.
My gut tells me to have the video, a component connection, the shortest possible, more signal over 3 wires. Whereas the digital out to the receiver is just one, and I'd just use a decent cable, but not optical. Plus a shorter componet cable would probably be cheaper.
Of course this is assuming I can locate the dvd player close to the projector. Turning behind me would be a pain in using the remote. I could maybe setup a mirror system to bounce off the IR signal. Or there must be a repeater type deal I could setup.
Thoughts?
Paul
Thoughts?
Paul
