which amp for SV CS-12 25-31 subwoofer
  • clearwaterms
    • Nov 2006
    • 110
    Im not sure if this is the right area to post this, Mod's if it's wrong, im sorry, please feel free to move it.
    okay, I ordered my new subwoofer (actually got it on ebay) it's an SVS CS 25-31. I am really excited, however now I need to know what I should use to power it. It says it will handle 350@4 ohms, but the active version only had 190 watts of power.
    I am thinking about using a plate amp, and just making a basic box to hold it, and hang it on the wall... given that I really like PE, I was thinking either the 0-audio Bash 300W amplifier, or the PE 240W amplifier.
    Which one is better?
    or
  • John Holmes
    • 2707
    Welcome to the Guide clearwaterms!
    I can tell you this. I've owned a 20-39 CS for a long time (yrs). The amp that I use pumps 125w @ 8ohm. Though I have been curious to try more power (because the sub is rated at 350w), I honestly have never felt the real world need to do so. My setup is very tactile, with good bass definition.
    So I think you could be happy with either amp. But, it never hurts to have more power.
    • clearwaterms
      • Nov 2006
      • 110
      Thank you for the response. Given the digital nature of the bash amplifier I am thinking that I will probably end up with that one, which is rated a little higher. I don't know if I will use the power, but given the slightly smaller stature of the 25 and higher -3dB point then your 20 having the extra power to get it into that 20 range might help.
        I'd definitely go with the Bash amp. It will drive that sub perfectly well! :T
        • clearwaterms
          • Nov 2006
          • 110
          one last question. I have a JBL e150, it's a 10 inch 100w could I use both at the same time? or would it be better to just put the JBL into storage?
            To be honest, You can use both...but it probably will take a ton of work to get everything to sound right and be balanced. You'd probably end up using the JBL for the 'upper' low frequencies (ie 20Hz-35Hz) and the SVS for the <25Hz. But the overlap is something you'd have to deal with.
            I'd probably just put the JBL to the side until I had another use for it.
            • djtetei
              Multiple drivers wiring vs total impedance vs amplifier power distribution
              by djtetei
              Hello to everybody
              I want to put together a stereo system containing 2 cabinets with a total of 8 drivers, each cabinet housing 4 drivers (2 woofers, 1 midrange, 1 tweeter).
              Each cabinet will have 3 enclosures (2 separate ported enclosures for the woofers, 1 enclosure for midrange and...
              16 January 2016, 11:27 Saturday
            • Chicagohonda
              Fair price for a used RB-1070 amplifier
              by Chicagohonda
              I found a used RB-1070 amplifier on Audiogon for $400, which retails new for $699. Does this sound like a fair price? Is there anything to be cautious of buying a used amplifier - given the seller has good reviews?
              05 April 2007, 08:30 Thursday
            • RebelMan
              Official CA-D200 Thread
              by RebelMan
              Classé is going to release for the first time in company history a Class-D amplifier called the CA-D200. It will produce 200 wpc into 8 ohms, 400 wpc into 4 ohms and is stable down to 2 ohms. It features a 1000 watt amplifier module and a switched-mode power supply with power factor correction, similar...
              09 July 2013, 15:13 Tuesday
            • meb46
              Stage Two – What next to power the dirty audio addiction?
              by meb46
              Having spent many hundreds of hours over the past 10 years (and a fair chunk of Jon’s time - huge shout outs) in developing some ambitious three and four way Avalon Acoustics inspired floor-standers, it is now time to divert my attention to a much needed Power Amplifier upgrade. If you’re not familiar...
              11 December 2016, 09:13 Sunday
            • number95
              Amplifier Matching with N800
              by number95
              Hello everyone,
              Finally i found this nice forum related to B&W.
              I checked the current topics and could not get a similar one so that i decided to post a new tread.
              I use B&W since 2000. My first speaker one a pair of N805 bookshelf. It was beautiful two way. Then i upgraded...
              14 March 2007, 17:01 Wednesday
