Video display
  • KennyG
    • Sep 2000
    • 746
    Video display
    If you could have any type of video display, what would it be, Direct View (Max is 40"), RPTV, FPTV, Plasma.
    I would assume your choice correspondes to what you feel produces the best picture...or are there other criteria?
    • 16156
    Depends on the locale.
    Desktop, Samsung is introducing a 24" diagnoal 16X9 flat panel display; I'd ditch my NEC LCD1810 in a heartbeat for one of those.
    In my bedroom I currently have an NEC XM29 Plus presentation monitor, which uses a Toshiba microfilter tube, a very nice large format design CRT, with a fine dot pitch for a large display tube. The Princeton HDTV monitor uses a 16X9 Toshiba Microfilter tube, 32" diagonal, and can do 1280X720P. I'd love to have one of them. The phosphor colors in the Microfilter tubes are individually filtered, and meet HDTV specs. With the individual filtering and contrast control, there's no need for a dark tint tube face, and light output is about 30-40% better than conventional tubes.
    If the RCA 38310 could do 1280X720P, instead of being limited to 1080i, I'd want to jump on one of those, it's a very nice 38" display. Also has a farily fine dot pitch. Check it out at your local Best Buy, includes HDTV tuner, $2999.
    In the living room, space permitting, a top of the line CRT (Sony G90, anyone? I don't think I could handle the noise and setup issues of a D-ILA.
    Since we're out in fantasy land territory, why not a 1280X768 Sony flat panel plasma display for the kitchen, so you don't have to miss the game in HD while you're cooking?
    And last, PC scaled video at 1280X1024, on Samsung D770's flat panel 17" displays, in every bathroom.
    • Doug
      • 118
      Jon, it's interesting you should say that. That's the exact setup I have on order, Yeah, all of it. (snicker) heh.
      I could go the princeton thats for sure for the bedroom. But my 35" Mitsu console does well. Main theater gets well first a new room, and then a nice mid line projector... I am not greedy like Jon and the G90, lol.
      <A HREF="http://www.catcables.com" <IMG SRC="http://www.htguide.com/lexman/other/sm_logo.gif"
      • KennyG
        • Sep 2000
        • 746
        I'd assume the reason you'd go with flat panel is because of space savings? Or has the picture quality improved enough to compete with other types of displays?
        • Markj
          • 322
          I am interested in FPTV DLP. I want to set it up then just use it. A RPTV is out because I do not have enough room for a big box. I and the only reason I don't have a FPTV is money or the lack of it.
            • 16156
            Hi Kenny,
            A lot of flat panel displays flat out stink- take the one in my work IBM StinkPad notebook. Or the one in the previous Compaq laptop I had. Ugh!! VERY bad directionality, basically, none of the colors and contrast are right at *any* angle, and as you change angle horizontally or vertically, they get worse and weirder.
            Now, the more recent generation of large flat panel displays have very good brightness and color uniformity on and off axis both horizontally and vertically. The first units I saw with this characteristics were NEC 20" displays that we leased for tradeshows two years ago. Hideously expensive, though! $3500 to $4000!
            Now, NEC makes an 18" display (Multisync LCD1810) which has the same characteristic, is bright, has useful color preset calibrations, and is the same resolution, 1280X1024. Samsung has a 17" model with excellent color and a better scalling processor than the NEC, in the 170T and the 770TFT models, and the new 18" 800TFT. The chip the Samsung monitor use have a better scaling engine with good interpolation, compared with the NEC LCD displays. Also, it locks on at higher scan rates at full resolution; the NEC stumbles at anything above 60Hz. For standard computing, that's not a problem; for DVD, less than optimal. Build quality is excellent, also.
            The acid test for the Samsung is that I setup an artist friend back East with a full custom PC, scanner, and the display calibrated to D6500, and now she is even using it for DVD playback, because, well, it obviously looks pretty cool compared to her Sony TV! She's been a fan of the concept of LCD displays; her last PC was a Sony laptop; she has a problem with the slight flicker of CRT setups, but the Sony laptop display didn't cut it either. Now she's in heaven. Her sisters were literally mind boggled the first time they saw DVD on her PC- they though she had HDTV, somehow, in the wilds of rural upstate New York!
            Now you can get a 17" Samsung for about $1150 with careful shopping; considering how long displays last compared with the rest of the PC, it's my standard recommendation for PC's I build for other folks. Space saving is a plus; my NEC 1810 at home takes up a LOT less real estate than the Hitachi 19" monitor it repalced, and that was a "short tube" version. It all works on a roll around desk/cart that was designed as a laptop docking station desk.
            • Wireless
              • Feb 2001
              • 140
              I would love to have a large screen, so probably a calibrated DILA with Greyhawk screen - 10' wide. While I am sure a G90 would give a better picture, screen size is probable best at no more than 96" and I think Joe Kane recommends no more than 80". Or maybe 3 chip DLP! Kenny, when can I have it delivered?
              John
              My HT Picts
              John
              My HT Picts
              • Robbie
                • 256
                Right now I'd take anything over 25"...
                Robbie
                • KennyG
                  • Sep 2000
                  • 746
                  Right now CRT FPTV is the way to go, many used units at very inexpensive prices. I have seen DLP, and it's just not really for prime time yet...but D-ILA is coming around, it won't be long before it can compete with CRT.
                  John, strangely enough a guy was selling a used 3 chip ampro DLP for just over 2 grand...it lasted about 2 hours and was gone!
                  Flat panel display is still to expensive for HT, even those 17 and 19" units that you speak of (Jon) are very expensive, but I do need to go have a look at one and see how good they are getting.
                    KE32TS2 32 inch plasma display
                    by Lex
                    Well, I quitely added this TV to supplement my front projection since I saw real quickly that I was going to crank a lot of hours on my PJ in a hurry. It's an HDTV monitor, the following applies: (Extracted from Plasma Depot since it was actually better than Sony's writeup.) I won't address each feature...
                    12 October 2003, 21:33 Sunday
                    Samsung announces new thin CRT display
                    by Andrew Pratt
                    source
                    Samsung Develops Worlds Slimmest CRT TV
                    Monday, July 19 @ 12:15:00 PDT
                    With CRT televisions ever die? Not with innovations like the Samsung 'Vixlim' which is touted by Samsung as the world's slimmest CRT television.
                    " The new CRT display,...
                    20 July 2004, 11:40 Tuesday
                  • Dean McManis
                    I ordered a Olevia 37" LCD display
                    by Dean McManis
                    I figured that I'd be holding off on HT purchases for a while until I saw some of the black friday prices on LCD displays.
                    I got up at 6AM on Friday morning expecting that nobody would be out that early (OK I'm new to black friday shopping) and I saw that there were hundreds of people...
                    26 November 2006, 22:06 Sunday
                  • kneptune
                    RT-1080 tuner - display is too dim
                    by kneptune
                    I just traded in an early version of the current RT-1080 tuner (was black version) for a newer silver version of the 1080 tuner (had to make it match the silver RSP-1098 - for the all important WAF).
                    As per the RT-1080 owner's manual addendum, the newer 1080's display now functions slightly...
                    20 January 2004, 12:32 Tuesday
                  • Quantronics
                    1098 Display shuts off permanently after holding down display button
                    by Quantronics
                    I know there's been a lot of anticipation in getting the 1098 display to turn off and remain off when you silent the display. My system can do it! There's only one problem, I can't back track and replicate it each time. I typically leave my system on 24hrs. I also turn on my zone 2. I'm not sure...
                    19 September 2004, 07:02 Sunday
