Harmonic Tech. cables
  • justair
    • Feb 2001
    • 4
    I,m considering the following Harmonic Technolgy cables for my home theater and would like user comments:
    Melody Line 8 ft speaker
    Cyber-Link digital
    Crystal S-video
    Crystal Component cable
    Precision-Link for sub-woofer
    I will be using a B&K AVR 307 receiver, Sony DVP S-9000ES dvd player, M&K 150THX speakers, and a Panasonic 42" plasma.
    Any other cable recommendations would be appreciated.
    Craig
  • John Kotches
    • Jan 2001
    • 140
    Harmonic Tech makes great cables. I've used them
    in my system from time to time.
    BTW, you didn't mention which digital cable, you'll be picking up, the copper, silver or platinum...
    Anyway, I think these will be good choices for you.
    Other options to consider:
    Better Cables
    Ixos Cables
    At a slightly higher price point, either move up the Harmonic Tech line, or checkout the wares of
    Nordost
    Analysis Plus
    Good luck.
    Editor, PC/Home Theater
    Secrets of Home Theater and High Fidelity
    My Home Theater
    NEC LT-150 specific page.
    My Home Theater
    • migliore
      • Nov 2000
      • 50
      You definitely should consider picking up one of their power cables if you happened to get all of these. I've found power cables to make as much as or more difference than interconnects/speaker cable!
      Rob
      Reviews and System
      Reviews and System
      • justair
        • Feb 2001
        • 4
        Sorry
        I planned on using their copper Cyper-Link. I planned on using all there lower end cables and upgrade as needed. I will also check out the other cable sites you posted. Thanks
        What Harmonic Tech cable or other manufacture's cable would you use for a sub-woofer?
        Which are better? Banana plugs or spades for speaker connections?
        Finally, would you run component or S-video from dvd to receiver or go direct to plasma fron dvd and not component switch with receiver?
        Craig
        • justair
          • Feb 2001
          • 4
          Rob,
          I assume your talking about the HT Pro-AC11 CL-3 power cord and not the HT "Magic" power cord? There is a big difference in price!
          Craig
