differences in metals used in cables?
Tags: None
gauge, material, geometry (coax, etc), connectors, shielding, solder, .. all affect the sound of a cable.
Rob
Reviews and System- Bottom
I know that the silver has a large effect on your wallet. lol. Actually, I can't say that I know these differences exist with silver. But gold is the best conductor I have always heard, and maybe silver has many of the same properties as gold. But then, I am no metalueralogist (sp?).
I do like a cable of substance. If it feels better, then it could sound better. Psychoaccoustics if nothing else!
Lex- Bottom
Lexman,
Actually Gold is a relatively poor conductor,
Silver is the best conductor, followed by Copper, then Gold.
The oxide of silver is itslef a good conductor.
Had to point this out, 'cause you're usually spot on on the details.
Editor, PC/Home Theater
Secrets of Home Theater and High Fidelity
My Home Theater
NEC LT-150 specific page.---
My Home Theater
NEC LT-150 specific page.- Bottom
Geometry will usually effect RF rejection. I think silver cables generally offer better detail. Even the material of the connector, brass vs. copper vs. gold. I'm far from an expert on this subject. The one to ask is Alan Maher.
Dead on John! Gold's conductivity is 79%, copper 97%, and silver 99%. Since gold is a relatively soft metal, it generally gets the best connection. Sort-a molds to your binding post at some level. Also resists corrosion and stuff.
Rob
If you are only contacting 50% of the area with silver, your total conductivity is .99x.50=.495. If you are contacting 75% of the area with gold, your total conductivity is .75x.79=.5925.
I'm just throwing numbers around and using resitance interchangable w/ conductivity
Rob
There are two reasons for it Lex, and we've hit on a few of them. Also, that gold sure does look pretty :-)
I couldn't find the numbers off the top of my head, but I think that Silver Oxide (aka rusted Silver), is more conductive than Gold is....
Haven't been able to prove or disprove that one yet.
Regards chaps,
My Home Theater
My Home Theater
Metalurically speaking, the analogy that comes to mind is a battery terminal. Leave it loose, and without any protective coating, the post on a battery and the inside of the cable will corrode to the point that contact is lost. I have had this happen before.
The process of oxidization of silver, is comparable. However, I cannot say that the corrosive oxidizing material is anywhere near the same. IF, the oxidization on Silver is conductive, then that would dispell my theory completely. However, if this theory holds, that explains the gold contact points. Yes, they are prettier as well
Lex- Bottom
This comes from a cable manufacturer, so take it with a grain of salt.....
At a micro-level (where the contact is made, gold is apparently a better conductor), but for runs of cabling, ie real lengths, silver is a better conductor.
This page also points out that Silver Oxide is a "very good conductor".
My Home Theater
My Home Theater
I have never been able to hear much of a difference in copper conductors, some very minor things yes, but between same type metals it was always minor...then I heard a friends solid silver cables on my system, and now that's what I use, silver interconnects and silver speaker wire.
The sound of silver is very different from copper, bass was tighter and better controlled (hence tighter) the top end has slightly less grain, and the midrange has more presence. The sound is a little more "analytical", which is what I like, that's why I dropped my tube preamp. I've never cared much for the "warm fuzzy" sound.- Bottom
John thanks for the lead. But I fear the author needs to do a little thinking upon which part of this statement is true:
How can the overall sound and quality be comparable, and yet Silver should outperform copper in every aspect!?!If two cables are made identically, except that one uses copper and the other silver of similar quality, the overall quality and sound will be comparable. The silver version, however, should outperform the copper version in every sonic and electrical aspect.
Lex- Bottom
Every time I read these speaker wire posts, I can't help thinking of the thin, cheap wire I've always scene inside speaker enclosures, and the aluminum wire used in the magnepan's.
However as of late, I've been trying better equipment, and keep finding it really does make a difference.
- Wes
My Home Theater- Bottom
Take a car that comes with two different engines, a 200 horsepower and a 220 horsepower.
One could say that they provide comparable performance, but the 220 HP engine outperforms the 200HP engine in every meaningful category.
I think this is the point the author was trying to make.
Maybe my analogy is an inappropriate one, but it's the only thing I could come up with off the top of my head.
My Home Theater
My Home Theater
I usually think of audio connects likes links in a chain. It is only as good as the weakest link. Now I know that if you have 1 inch of poor cable in a 25 foot run, it will be much better then 25 feet of poor cable. But how much difference can a 4 foot $10,000 cable make on a speaker that has 2 feet of $0.10 cable inside. I think that may be one reason why people with basic speakers may not notice much of a difference, while those with top quality speakers do. Also most amps have fairly thin printed traces inside the amp, so how does removing the fuse on the speaker make a huge difference? Actually I think it makes almost no difference, but humans can detect differences so small that they almost can't be measured. And once you learn to detect these differences, they show up like a sore thumb.
- Wes
by Andrew PrattThis topic often gets the geekers and tweakers all fired up hotly debating the merrits of both sides and inteligent debate can be fun and a learning process for both sides. My point with this post though is to tell you what I've discovered twice now with my IXOS interconnects. Several moons ago I was... -
by migliorePlease put yourself in one of three categories:
a) never tried after market power cables
b) tried them but didn't make a difference
c) tried them and did make a difference
If you tried some, which cables and what is/was your system?
by rlinI am not sure this is the right forum to bring up this subject but since I am using the RSP-1098 I just want to know other people's experiences...
The RSP-1098 is my first true venture into separates...before I was using a Denon receiver as a Pre-Amp and a Carver 705 THX 5 Channel power...-
Channel: Club Rotel
by indiebandsMy 803Ds were delivered on Tuesday and I have been having a good time during the burn in period (not sure neighbors can say the same). My local stereo guy has recommended speaker and interconnect cables which seem like a good fit to me. However, he's also installed a pair of fat power cables for each...-
Channel: Club B & W Speakers
by Andrew PrattOkay I know this is a taboo topic but its an interesting topic. I used to sit in the camp that was more geeker then tweaker in that I didn't believe that there were that great a difference between various cables. Maybe it was the lower quality of gear I had or just the cables I'd tried but I didn't...-
Channel: Audio Hideout
- Loading...
- No more items.
