So? Which do you use/prefer. I have optical right now, but I have setup a home theater with coaxial, and both sounded great. Is there any real world difference, or is it just preference?
toslink (Optical) or coaxial?
Well, this one ranks right up there with "cheap speaker cables vs. expensive speaker cables".
Personally, I heard a difference and like coax better. In the various attempts at A/B-testing them that I've been around, to me Toslink had a bit of a harsh edge to the sound. However, YMMAPWV (your mileage may, and probably will vary)!.
Honestly, I have used both early on and could not tell any difference in quality. But I have been using, for some time now, one of Doug's coax cables, running from my Sony 7700 to the Denon. It beats anything I heard from cheaper coax or the mid-priced optical cables I had used previously.- Bottom
Originally posted by FishyI also prefered the coax over the optical connection. Both were good quality cables, but just found the quality from the coax better.
FishVincent.
I don't want the world. I just want your half.- Bottom
