Expert Advice Needed
  • tags
    I am in the market for a new av receiver........my room is 25x15......I am planning on going with the JBL - (6) 100w satellite speakers with a 300/400w sub......I do not want to spend more than $500 on a receiver........any suggestions would be greatly appreciated.......Thanks!
  • tags
    Ok.....after reading some threads......I have narrowed it down to either the Pioneer 1015 and the Yamaha 5890....which system should I get??....some threads are saying something about the Pioneer not having Lip Synch correction.....is that a big issue?? Thanks!
      It's not a super big issue, but it's a featuer that can be useful at time.
      I've had yamaha and I think they are great receivers. They are a little bit on the bright side, but should match very well with the JBLs.
        Twin Moderator Emeritus
        • 16706
        Lip-synch "should" only be a problem if you use an external video scaler. Otherwise you shouldn't have to use it
