Krell EQ question
  • kurtholz
    • 345
    Krell EQ question
    Hi All
    let me predicate my question
    this is the tough question of the day, i know what a huge amount of work could go into an answer, so if someone knows a book or website with this info, i am happy to try and figure it out myself,
    i have tried playing around with it, but just can't get it right
    OK, the question
    I have the Krell showcase 7.1 processor, at the room EQ setup menu, there are six filter types,
    notch filter
    peaking filter
    high shelf filter
    low shelf filter
    high pass filter
    plus they all have 3 parameters that can be varied, (freq),(shape),(Level)
    i tried dealing with my EX dealer, but they dont have a clue, also, emailed Krell, but they were about as much help as the dealer ( EX) :-)
    if anyone can give me some help on what these filters do and how they affect sound, maybe some general opinions on what settings i should use, i can tweak it from there
    any help mucho appreciated
    thanks
    Kurt
    notch filter removes a narrow band peak (aka spike)
    high shelf filter/low shelf filter, these are broad range filters used to add or remove high or low frequencies. They effect the overall tonal balance
    low-pass filter removes frequencies higher than the cut-off frequency, allowing the lower frequencies to pass through
    high-pass filter removes frequencies lower than the cut-off frequency, allowing the higher frequencies to pass through
    peaking filter emphasizes frequencies near the cut-off frequency which emphasizes a specific frequency band
    In order to successfully use any of these you need test equipment to take in-room measurements. This isn't something that can be done by ear.
    • Duke
      • 10
      Yea. The Krell EQ can be quite complicated. I have the showcase so I have played around a bit. I used it to tame a big swell I had in my sub. I also have a PDF that tries to explain it. If anybody would like a copy, just PM your email address and I will be happy to send it.
      • Claude D D
        • Jan 2003
        • 465
        I agree 100%. Any EQ or room treatments done without knowing where the attention is needed can cause more problems than it solves. We have a fellow in our store that uses a Iasys to "shoot" a room and determine what areas need attention. If you can find someone in your area who performs this service it can be invaluable. :T
        • gilbert61e
          Looking for Bass Alignment Filter for Bowers and Wilkins 800 Series Speakers
          by gilbert61e
          Looking for the bass alignment filter for B & W Bowers and Wilkins 800 Series speakers.
          Considering the Krell, JPS Golden Flute, anodyne, KBX Krell, or Northcreek (801/802) bass alignment filter.
          The stock/original B & W filter, the one with the wall-plug, will...
          11 April 2009, 11:23 Saturday
        • Aussie Geoff
          RSP 1098 Wish List V2.0
          by Aussie Geoff
        • Nick M
          Thiel & Krell
          by Nick M
          I spent about four hours at my local hifi shop yesterday listening to various combinations of gear from Paradigm (Signature Line), Thiel, Rotel, and Krell.
          After listening to my Signature S4's at home for many hours I have picked up on a couple things I would like to improve upon with...
          18 January 2007, 11:30 Thursday
          Active Cauer-Elliptic filters?
          by BobEllis
          Looking at Jon's filters got this active filter die hard thinking. Amplifiers, opamps and vector board I have aplenty. So rather than spend the bucks on passive XO's...
          Is there any advantage to using an active elliptical filter that approximates an 8th order L-R over just doing the...
          22 December 2005, 22:58 Thursday
          Offloading low frequencies from your floorstanders
          by bigburner
          For those of you who have floorstanders and a subwoofer, how many of you offload the low frequencies from your floorstanders so that they only play through the sub when you are listening to 2-channel music?
          In my system my ASW750 subwoofer is wired in between my preamp and my amp so that...
          26 February 2007, 03:53 Monday
