Optical Splitter
  • DLA
    • 35
    Optical Splitter
    Is there such a thing as an Optical Splitter? I have 2 units I want to plug into my single A/V Optical. If so are ther hazards?
    If you like loud bass, check out my songs.
    DLA Songs
    Never had the need for one, but a quick Google turned up this.
    • George Bellefontaine
      • Jan 2001
      • 7636
      Radio Shack also have one with several optical inputs for around $29 US. But not sure how many outputs it has.
      My Homepage!
      • H.Donald
        • 477
        You can buy them on eBay for 6 bucks....hazards or drawbacks I wouldn't know...never had the need.
        • JetFlyGuy
          • 102
          I have an extra one that I dont need anymore. IT is technically called a Tosslink splitter. Pay for shipping and I will give it to you for free. PM me if you want it.
          • LikeCoiledSteel
            Toslink Splitter
            by LikeCoiledSteel
            Hi Everyone,
            I am interested to know if anyone knows if there is a toslink splitter available on the market. I use a universal player (Denon 2900) with only 1 optical output. I would like to send it to 2 components (outboard Dac, ht preamp).
            I would like to avoid the coaxial output...
            23 January 2007, 12:44 Tuesday
          • Sid
            DVD-2900 Multi-input vs Optical to RSP-1066
            by Sid
            Can anyone suggest any clues to make the multi-input from the DVD-2900 sound as good as or better than the optical input to RSP-1066.
            I haven't checked on the speaker levels on the DVD-2900, but it sounds like the problem is more than speaker levels, sounds a little flat compared to the using...
            15 September 2003, 11:48 Monday
          • safaa426
            can i use vga splitter for dvd player?
            by safaa426
            hello every one , i`m new here.
            i just have a Q,
            can i use vga splitter to split a component signal from dvd player using powered vga splitter.
            the reason is i want to drive the sony tv and panasonic pj at same time,using a dvd component signal.
            if this is possible...
            28 December 2004, 01:05 Tuesday
          • sirbogey
            best HDMI 4x2 splitter for RSP-1098
            by sirbogey
            I'm looking for an HDMI 4x2 or 5x2 splitter to put on top of my RSP-1098. I need at least 4 HDMI inputs (v1.3) and for sure 2 HDMI outputs; 1 for the projector the other for the TV. Sound will be decoded thru the 1098.
            I also got a logitech Harmony One remote, so would love to get access...
            04 December 2010, 06:41 Saturday
          • OldMan
            4x4 HDMI Matrix splitter
            by OldMan
            I have been doing some research on purchasing a 4x4 HDMI matrix splitter and one common problem plagues them all. And when you think about it, the problem makes perfect sense and can NOT be fixed. (But you can get around it, see below)
            Let’s say you have two TVs. One is 3D capable and...
            10 July 2016, 10:42 Sunday
