hope i can get some help, i am currently using Levinson 27.5 to drive B&W 704, and marantz ma500 for B&W HTM7.
Problem is the levinson has such a different sound to the marantz that i find no matter how much i adjust the settings it is always either to loud or to soft. The sound is very bright from the centre and i think getting an amplifier which would match the levinson better will help to balance the front channels. All three speakers use audioquest pikes peak cable and jaguar interconnect, so it cannot be a cable problem. I have put a small mat in front of the stand the centre is on to help with the wooden flooring reflections and it has helped a bit.
Unfortunately i cannot ship stuff from the states over here because of voltage problems so i am bound by what the dealers have here in their second hand sections. Also don't want to spend a fortune so second hand is the best way to go, but i am pretty open to suggestions.
I have a rotel 1080 and was thinking of using that for the centre but don't know if it would be a good match, as the levinson is so smooth.
Hope i will be able to get some suggestions
Thanks in advance
Thanks in advance
When two channel listening, the base traps perform a slight improvement as I do not have the volume that loud. However, during movies they are a bigger improvement as my subwoofer if a 15" Paradigm Reference Servo-15. It's excells at at LFE below 40hz which tend to get a little boomy when played at robust volumes.
