How to mute ground noise/hissing?
  • AwArEnEsS
    • 151
    I am connecting my Pc to powered speakers using a 3.5mm to 2 rca + Y splitters. I notice some hissing noise which I expected. While I am listening to music or playing video, it's mostly not noticable.
    While I am playing older games, not a problem but if I start playing a resource-hungry game, psu draws more power and the noise starts to irritate.
    Should I buy a Dac, a ground isolator or a ci box to eliminate hissing completely? Which would be less expensive but still make the job done?
    There are a few other things to consider. I want to be able to connect my powered speakers to Tv via tv's optical output and speakers' rca output. I bought a dac for it but it seems corrupt.
    Also I want to be able to connect my powered subwoofer to Pc and if possible to Tv too, should I buy a multi channel (5.1) dac for it? If I just buy a stereo Dac, connect my speakers to it and then connect my subwoofer's rca line-ins to powered speaker's Xlr output using a Xlr to rca +Y spitter, will my subwoofer work?(without having to buy a 5.1channel dac)
    So I want to be able to do all of the things which I mentioned, if possible I just want to buy just one device and accomplish all of these. What should I buy, which type of device?
    The universe arises from definitionless awareness.
    Master of None
    • Jan 2014
    • 1662
    When I ran into this I switched to shielded cables and a ground isolator. This happened at a flat I use to rent 14 years ago. When I got a house I ran dedicated circuits for the listening room. On my current Soekris DAC I use RCA out to XLR when I want to use a sub for more bass for a 2.1 setup. The XLR out on the DAC go to the Front L/F.
    Painter in training
    • AwArEnEsS
      • 151
      Thanks for your answer.
      Actually I wonder if I connect my powered speakers to the stereo dac's L/r outputs and then connect my powered subwoofer directly into my powered speaker's subwoofer output, would subwoofer work. The dac I have (which seems corrupt) and the dac which I have ordered don't have Xlr output, they just have L/R rca outputs and the other one has a 3.5mm output additionally.
      • nick.h
        Question: Optical VS RCA/XLR for Audio
        by nick.h
        I current use an optical connection from my DVD player to my A/V Reciever. It also supports RCA connections for each channel.
        Is there any benifit in using RCA over optical?
        I know if you use seperates from a processor it uses RCA/XLR to the amplifier...
        26 March 2007, 06:01 Monday
      • SoundEngine355
        RCA or XLR from PRE/CD/AMP
        by SoundEngine355
        What do you use between your Classe PRE/CD/AMP RCA or XLR?
        My distance from the CD to AMP is only 1m, so I am tempted to use RCA, however I have heard XLR can give 2-3db more output.
        RCA
        12.50%
        3
        XLR
        87.50%
        21
        13 September 2009, 06:10 Sunday
      • alpina
        Balanced XLR vs RCA's - what's the deal?
        by alpina
        hi guys,
        finally geting around to the wiring end and am wondering what the deal is between balanced XLR vs RCA? What makes one better than the other and what are the real world sonic differences between the two?
        cheers,
        julie
        29 April 2006, 00:36 Saturday
      • AwArEnEsS
        Using a Dac, no sound is coming from Pc or Tv
        by AwArEnEsS
        No sound from Pc or Tv using a Dac
        I have bought new speakers and ordered many cables and a Dac.This is my first Dac and it's a cheap one.
        It's not a usb Dac.I connected an optical cable to Pc and connected the other end of the cable to the Dac's optical input.Then connected...
        23 November 2024, 19:21 Saturday
      • misterdoggy
        Is there Volume control using XLR Bypass
        by misterdoggy
        I think I am going to buy the Goldmund Digin which is a DAC pure and simple, one input to 2 analog outputs. they Say this is top DAC stuff and compares with their Nemisis line in quality.
        So I was thinking of having my Ayre D-1XE transport send the digital signal Rca to the Digin which...
        09 September 2005, 07:43 Friday
