Audio Dinosaur and Digital Audio
  • AudioRube
    • Sep 2014
    Here goes...
    Greetings,
    Audio dinosaur here. First allow me to confess and apologize for my utter lack of experience and knowledge per the digital audio realm. I'm an old school two channel analog audio guy finally...about 25 years late, attempting to advance to a more complete transition to digital beyond my first generation CD player and my own computer usage void of any music file functions utilization.
    I recently purchased a Marantz CD6005 and a Tascam CD-RW901MKII for integration into a very "vintage" audio system I've had mothballed for a long time. Those components are a David Hafler DH500 two channel amp. A Hafler DH110 preamp, a Yamaha PX-3 turntable, a Teac V900X cassette deck, Tandberg TD 20A reel to reel and carver TX-11 tuner. I've discarded my first gen Yamaha CD player for the new. Haven't used either magnetic tape machine for a long time. Speakers are ADS L1530's
    My primary reasons for the new pieces are for recording playlist CD's for mobile playback. I'm also just now getting into ripping and burning CD's on a desktop and couple notebook PC's. Bought a new Dell recently to serve as a dedicated music file device only. Which brings me to my initial questions. I have ripped about a 3rd of my CD collection, then burned a couple CD-R discs for mobile playback. Ripped using lossless WAV format as I understand this is better for reproduction than compressed formats, which I would anticipate. I was a little disappointed with results. Quality of reproduction is fine. It's the actual sound level that seems lacking to me. Back in the day I was able to produce very good results per the magnetic tape medium via the readily tweaked recording levels and the ability of quality tape to accommodate moderately boosted recording levels without overloading so to speak, avoiding the potential for resulting in terrible recordings. I am completely without any knowledge of this capability per digital recording. I understand the detrimental aspects of tweaking recording levels of digital material. No nothing about any equipment, software or back panel digital coax and optical connections (also new to me vs. the old RCA analog connectors I'm familiar with) that may facilitate better recording results. Each of the new pieces...the Marantz and Tascam have these ports.
    First thing...I know I need a new pre-pro and have been shopping with an eye on future expansion. My budget is pretty restricted...or very restricted. I don't need high end, bells and whistles so I'm leaning towards an Outlaw 975 surround processor to route my sources through. For digital and home theater expansion purposes...I know the Hafler preamp must be replaced. The Outlaw would replace my current tuner as well. I'm wondering if I could expect better digital recordings using the Outlaw 975 in conjunction with the Marantz and Tascam? Any advantage over PC based ripping / burning? Also wondering if using the various digital in / out coax or optical ports for sources and recording equip would improve results? The Tascam manual specifies signal boosting is a no-no via a source per the RCA analog ports. That much I knew. The manual doesn't seem to address the possibility...or capability of record level tweaking per sources via the digital ports. Maybe no record level boosting is advisable during digital recording under any circumstances? Always to be recorded at zero boost? If that's true I guess I don't understand the purpose of recording level controls the Tascam has. This is what I don't know. I've also read of software...like "Digital Performer" per PC based music reproduction that seems to allow tweaking the signal. Maybe that's what is needed for quality reproduction on a PC?
    I hope I can figure some stuff out. Producing good quality recordings was always an enjoyable hobby for me back in the days of magnetic tape.
    More ??? about PC music file manipulation ahead...but that's quite enough for now, I'm sure. I'm looking to load music files onto memory cards and flash drives as well. The mobile deck can accommodate these as well. Hoping to rid my vehicle of the bulky CD cases. If you've taken the time to read all this, know I really appreciate it.
    • 16170
    Without being there and watching exactly what you're doing, it's hard to know if my intuition or guess is correct, BUT, as I have a lot of experience with magnetic tape recording going back to the early 70's, both consumer and pro, what i think you used to do was overdrive your tape analog tape recording setup and increase the average loudness by basically using the tape as a peak compressor, saturating softly on the peaks and limiting the peak volume. Generally, I don't like that kind of effect on program, even when I listen to rock and jazz, and especially not with classical music. You DON'T want to peak over drive a digital recorder, because you get very hard clipping with a lot of HF distortion- no soft clipping (like a tube amp) but hard clipping like a solid state amp.
    BTW, I'm quite familiar with the components you mention, as well as substantially earlier stuff...
    With regards to the sound level, and not meaning to be sarcastic, this is what the volume control is for- just turn it up a bit higher until you get the average levels you want- of course, without compressing through the recording process, your peaks will be higher. These days a lot of us spend good money to get recordings that are not peak limited and that do have a wider intrinsic dynamic range- you may have a different preference, and of course, it is a free world-. :W
    • aarsoe
      • 795
      You should never play with recording levels on digital - statement only applies to cd ripping and copy.
      There is no possibility to go above 0 DB without a really nasty distortion that will at best blow all your protection circuits on any newer amp or maybe do even worse things. On older gear like you use it could blow a speaker unit or two.
      However I am wondering if what you are looking for or describing is the ability to have your gear sound "full" even at low volumes. Believe the bug has bitten you once again and that only new gear will solve the itch... Sorry :-)
      • Bob_Collins
        Tape loop / record-out source select
        by Bob_Collins
        Ok guys, I have a question to pose. Are there any Home Theater receivers or processors out that include the venerable, old “tape loop” function? I’m referring to the ability on older stereo equipment to select a source for recording out to the tape outputs, but still allow you to choose to listen...
        29 May 2003, 12:20 Thursday
      • NMyTree
        Best For Recording/Burning CDs?
        by NMyTree
        I'm trying to figure out which is the best way to go, in finding a way to make quality sounding compilation CD-Rs of my favorite songs, artists, genras and so forth; for the purpose of my own enjoyment. I basically want the best quality sound, I can afford and I want to be able to do fade-in and...
        03 December 2004, 11:18 Friday
        Retro Digital comes to town: The Avatar CD Transport from Denafrips
        Do you ever see something on the web and right away, your first reaction is "I gotta have one, muy pronto!"
        For whatever reasons, the new Denafrips Avatar CD transport struck that chord for me.
        As an aside, how many of you knew that in 2019 vinyl outsold...
        25 September 2020, 10:14 Friday
      • STV_Keith
        Yamaha DSP-A1 DVD input vs. tape 2 monitor...
        by STV_Keith
        Hello. I recently acquired a Yamaha DSP-A1 to replace my aging DSP-A1000. The A1 has all the newer HT stuff that the A1000 didn't. I am using the digital coaxial from my DVD player for audio, and component video straight to the TV.
        I also use the Tape 1 record out to go to my equalizer,...
        27 September 2004, 23:24 Monday
      • madmac
        Tape out's on Rotel RSX-1057
        by madmac
        Lately I've been using the tape out's on my Rotel, sending the stereo signal to my headphone amp for all sources. I never really thought about trying the tone controls on the amp, figuring that the tone adjustments would not work through the tape out's but alas.......THEY DO !!.
        I always...
        24 April 2013, 10:16 Wednesday
