Need advice
  • roofa
    • Jun 2013
    • 8
    Need advice
    After hurricane sandy I finally get me man cave. I had an av guy come over and told me were to run my speaker wires and now I'm ready to purchase some equipment I can't get him on the phone. I want to install two recessed cieling speakers for te rears and three non resessed speakers for the fronts and center channel. The reason I can't do resessed in front is because there is a header in the way. I also need a sub to wich I ran coax. Does anyone no of a descent set up for me? I'm also looking for a receiver. Thanks in advanc. Tim
  • Kal Rubinson
    • 2109
    I am afraid your post is too vague. What do you mean by "three non resessed speakers?" On-wall? Free-standing? What is your budget and what are your sources? You might get a feel by going to an audio store and then get back to us.
    Kal Rubinson
    "Music in the Round"
    • roofa
      • Jun 2013
      • 8
      On wall speakers. I have been looking at stores but it seems they are either trying to sell me all package deals not splitting up recessed and wall mount I'm tryin to keep it as cheap as possible but still would like some quality.
      • roofa
        • Jun 2013
        • 8
        I'm not sure what u mean about resources and thanks for getting back to me
        • Kal Rubinson
          • 2109
          Try better stores or A/V installers. Also, put a number on "as cheap as possible" as we all have different meanings for it.
          Not resource, sources. What are you playing: CDs, LPs, DVDs, streaming, BluRay, etc.?
          Kal Rubinson
          • roofa
            • Jun 2013
            • 8
            Sorry misunderstood. I would like the whole system around a grand but I'm also realistic. And by the whole system i mean reviever, five speakers, and a sub. i got babies so im not looking for load just clear. Using it for surround tv and plugging the iPad in or blue tooth.
            • roofa
              • Jun 2013
              • 8
              I will try a better store. I was tryin too order this stuff on line. About the uses its mostly for surround tv, blue ray, and plugging the iPad in or blue tooth. I was checking out crutch field and found some reasonable priced Polk's for the cieling and some fronts that mount on the wall
                I have V experienced friends who are V happy with Martin Logan Helos line of in-wall speakers.
                I have not heard them, but their testimony is good enough for me.
                Your current budget is a bit limiting, but if you consider taking the path of continuous upgrade, may I suggest you invest in higher grade speakers first, then upgrade the your electronics over time.
                JMHO, YMMV
                • Kal Rubinson
                  • 2109
                  I think that Crutchfield would be a good source for you since they offer very good support, on-line or by phone.
                  Kal Rubinson
                    Well advised.
                    Thank you, Kal.
                    • roofa
                      • Jun 2013
                      • 8
                      Thanks for your advice and ill let you know what I go with. I think I got to raise my budget a little also
                      • roofa
                        • Jun 2013
                        • 8
                        Is there a way to convert coax to RCA for the sub. An av guy told me to run coax and now I can't find any subs or receivers with coax. Thanks
                        • Kal Rubinson
                          • 2109
                          The cable isn't the issue; it is the connector. Prefab coax comes with either F-connectors or, for lab use, with BNC connectors. You can get simple adapters from either one from RadioShack or Monoprice.
                          Kal Rubinson
                          • roofa
                            • Jun 2013
                            • 8
                            And I should just use the adapters on both receiver and sub?
                            • Kal Rubinson
                              • 2109
                              if both are needed, certainly.
                              Kal Rubinson
                                East Coast and hurricane Sandy
                                by Lex
                                We would like to wish our East coast friends, particularly in NY/NJ area well. Many of them cannot log in now, of course, with power out for over 6 million people. I understand at least one person was killed even into Canada as a result of this storm and at least 16 in the US, and our coastal waters,...
                                30 October 2012, 10:39 Tuesday
                              • indiebands
                                Freestanding surrounds/side channel speakers (for 803D anchored system)
                                by indiebands
                                Hi all,
                                Newbie post here, but I did search forums first.
                                Waiting on delivery of 803D fronts and Vincent Monoblock amps for stereo. Considering going for the HTM2D center. Currently have Polk side/rear channel speakers which are wall mounted in current apartment. Looking...
                                27 March 2009, 19:41 Friday
                              • Legairre
                                1066 allows EX mode on non EX DVDs?
                                by Legairre
                                My 1066 is running version 1.49. Certain movies like Armageddon that clearly aren't DD-EX allow me to put my 1066 into EX mode. I know the 1066 will automatically do XS mode whenever the back speakers are set to "yes", but EX on non EX encoded movies? Shouldn't the 1066 be looking for the...
                                28 May 2003, 21:06 Wednesday
                              • Bing Fung
                                Dell Machines Are Non Standard ?
                                by Bing Fung
                                Well we always knew that Dell, Compaq, Gateway...etc, typically are proprietary in design, certainly for the desktop machines, however it seems even Dell towers may not be fully upgradable with off the shelf components that are non Dell. Sounds like a cash grab scheme to me as the Major PC makers seem...
                                15 April 2002, 16:35 Monday
                              • Sonnie Parker
                                Anamorphic vs. Non-Anamorphic
                                by Sonnie Parker
                                Since I'm just getting my new Toshiba Widescreen RPTV in I've been trying to understand a little more about Anamorphic and Non-Anamorphic DVD's.
                                Basically I know Anamorphic is better, but why?
                                I happen to be looking at 2 DVD's that are not on the Anamorphic database at...
                                07 December 2002, 17:57 Saturday
