Cambridge Audio 540D Thoughts/Problems
  • Hoo Fighter
    • 3
    This is my first post on this site. Hope you find it helpful. I've have had the CA 540D for about 2 months now. At first, I was thoroughly satisfied. Sharp looking unit, nice remote, musical sound, good picture, good value. I use it both to play movies and to play CD's and DVD-A's. My system is as follows:
    2 pair Soliloquy 6.2
    1 Soliloquy C3 center (plan to add an S!- sub at some point in time)
    Aragon 3005 Amplifier
    Theta Casa Nova (can't wait for the Casa Nova II to come out to upgrade)
    Anyway, for CD and movie play, the player has performed very well, except that one issue has arisen. DVD-A has introduced another issue.
    The first issue, and I hope to hear if others are having the same problem, is that the unit overheats rather easily and stops playing. I have the unit above my amp, but below my preamp on a seperate shelf that is open in the from and the back. There is not much room above, or below the player. After 1-2 hours of playing at moderate or even low levels, the unit overheats (I'm assuming the laser is the problem) and it stops playing. Has anyone else experienced this? Could it be a defective unit? I do plan on getting another stand which will be a little more open, but I am very surprised by this. On the other hnad, given the light weight, perhaps I shouldn't be. Something has to give for the low price, right?
    Then second issue has become very annoying. I have 6 DVD-A's and the player will only play 2 of them. I contacted Audio Advisor (highly recommend them), who I bought the unit from, and they said CA was aware of the problem and working on a fix. Since the player is software upgradeable, this may not be a big problem, but it sure seems like one now!
    All and all, given what I now know, I would not have purchased the unit. If the software upgrade addresses the DVD-A problem and the new stand addresses the overheating, then I'd change my opinion and go thumbs up as the unit does many things well.
    Hoo Fighter
    Sorry, no experience with the player, but that doesn't sound good IMO. As long as the clearance is around what is specified in your owner's manual, you shouldn't be experiencing this kind of heat buildup/shutdown. Having said that, setting it above the amp is going to put it in the hottest spot possible in your rack. The combination of the two units' heat output may be enough to trigger the shutdown. Test it with a small fan blowing across the player and see if that keeps it up. If so, the first thing I'd do is move the amp up and put the Cambridge below it. Then, if it still continues, I'd send the unit back and get another.
    • theMaximus
      • 179
      I've had mine for about one month and have not noticed any problem with heat. I do have the 540D on a glass shelf by itself with about 6" clearance on top and completely open back side. I have three DVD-A discs (Diana Krall, Metallica, etc...) and they all play just fine in both stereo and multi-channel.
      The only problem I had with the player came after about 12 hours of nonstop CD playback. I don't normally use it as a CD Player since I have CA Azur 540C CD player I use for CD playback. I was playing CD in 540D to burn in my new Ecosse digital coax, and 540D started to make some clicking noise while the CD was still playing. When I turned it off and on again, the noise went away. It has been working fine since then.
      I heard about some of the issue with DVD-A, and I requested my dealer for a replacement even though I have not experienced any problem so far. My dealer (Spearit Sound) informed me that the lot approved by Cambridge Audio should be available for shipping in a couple of weeks or sooner.
      Victory Shall Be Mine!!! :heh:
      • Hoo Fighter
        • 3
        Thanks for the feedback. An update. I've heard that an upgrade CD will bwe available next week, so I'm guessing I'll see one in about 2 weeks. I have since purchased 2 more DVD-A's and they don't play either....very frustrating. Now, my main concern is the overheating. I'm going to place it in an open area and see what happens. I wish I had 6 inches of space in my system, but it's move like an inch....
          • 16101
          Hmm, you have it above your Aragon Amp, and below the preamp.
          Sounds like the CD player isn't overheating by itself, but being baked by the power amp. I don't have any of the new HT model Aragons, though I do have a new set of Palladium 1K's, an original set of Palladiums, an 8008 X3, and an 8002. They ALL run pretty warm, and I wouldn't put a preamp or CD player on top or close by. Laser sleds are kind of sensitive to heat.
          Try separating them; move the amps to a separate well ventiallated area, or move the CD player, just as an experiment. It COULD be some other problem with the CD player, but I wouldn't be surprised if this fixed the problem, at least temporarily.
          Best regards,
          • simonc
            Improving HT by new DVD player or Blu ray player
            by simonc
            Hi all,
            My system consists of:
            Plasma TV: Pioneer PDP-427XG - XGA Resolution (1024 X 768 ) with 2 x HDMI
            DVD player: Pioneer DV-696AV - (video out HDMI conversion to 720P/1080i).
            CD player: Cambridge Audio Azur 640C
            AV receiver...
            16 December 2008, 23:23 Tuesday
            Cambridge 640C vs Marantz DV7500 vs DAC1
            by audioqueso
            Looking for my next upgrade and would like to hear everyone's comments, suggestions, etc on my ideas.
            My current setup:
            Source: Pioneer Elite DV-37
            Pre-Amp: Marantz SR-6400
            Pro-Amp: Parasound HCA1500
            Spkrs: B&W 805 & Velodyne SPL-800II...
            01 October 2005, 07:21 Saturday
          • Paul H
            by Paul H
            I've been reading some very favourable reviews of the Cambridge 540D as a CD and DVD-A player. The general sense seems to be that this is an extremely good value in a low-mid priced player. It also seems to get good comments on build quality, which suggests that it might (thinking of future upgrades)...
            09 July 2004, 20:13 Friday
          • Bluespower
            DVD/DVD-A Player Recommendations
            by Bluespower
            I know this topic has been beaten to death but I really wouldn't mind hearing a few recommendations as I begin my quest (again). I'm in the market for a DVD/DVD-A player with audio quality being the prime consideration (a "universal" player with SACD could be considered even though I don't...
            14 September 2006, 19:27 Thursday
          • pasteur
            rotel dvd 1050 vs cambridge audio 540d
            by pasteur
            hello to everyone. I am a new member.i want to put together a home theater system and after a lot of research i narrowed the field to two brand names: rotel and cambridge audio. I would like to know if anyone compared (listened)the rotel dvd 1050 with Cambridge audio 540D in terms of sound not technical...
            14 August 2005, 20:50 Sunday
