Help!! Denon 1804 receiver for klipsch speakers?
  • caveboy
    • Apr 2004
    • 3
    The power handling of klipsch reference bookshelf speaker RSX-5 is 75 watts continuous (300 watts peak).
    Klipsch Rsx-5 specfication as below
    FREQUENCY RESPONSE:
    92Hz-20kHz ±3dB
    SENSITIVITY:
    93dB @ 2.83V / 1 meter
    POWER HANDLING:
    NOMINAL IMPEDANCE:
    8 ohms compatible
    ENCLOSURE TYPE:
    Bass-reflex via rear-firing port
    DRIVE COMPONENTS:
    Two-way system using one 1" (2.54cm) magnetically shielded, titanium dome compression driver tweeter with a integral round 90° Tractrix® Horn and one 5.25" (13.34cm) magnetically shielded, aluminu
    TWEETER:
    One 1" (2.54cm) titanium dome compression driver
    HF CROSSOVER:
    2000 Hz
    WOOFER:
    One 5.25" (13.34cm) Cerametallic® cone
    INPUT CONNECTIONS:
    One set of binding post speaker terminals
    DIMENSIONS:
    12.5" (31.8cm) x 6.5" (16.5cm) x 9" (22.9cm)
    WEIGHT:
    7 lbs. (2.7kg)
    ENCLOSURE MATERIAL:
    ABS, cast aluminum baffle and base
    FINISHES:
    Black or Silver
    MOUNTING:
    Base swivels 360° for on-wall mounting via keyholes
    YEARS BUILT:
    2003 -
    Would the denon AVR-1804 receiver be able to power the speakers??
  • Kevin P
    • 10812
    The AVR-1804 is rated at 90 watts per channel, so it should drive the RSX-5s no problem. With a 93 dB sensitivity you don't need a lot of power to drive those speakers. You'll be able to push 111+ dB SPL at 1 meter, more than enough for most home theaters.
    • praneeth
      Home Theatre System
      by praneeth
      Hi All,
      I have seen ur valuable comments and expert opinions reg. HTS.
      I am planning to go for HTS i have LX3600D in mind. Its a build in DVD player.
      with following spec:
      Philips Home Theatre - 9000 W
      The full cinematic sound experience can be yours.
      04 July 2005, 03:44 Monday
    • xshen
      magnetically shielded speakers
      by xshen
      Hi:
      I am going to purchase Rotel preamp 1068 + amp 1075 in next few weeks. I still need to decide what speakers to match them. I have a little problem with my room size. Due to the limited length of the wall that I am going to put both TV, AV rack, and two speakers, either I have to put...
      30 April 2004, 12:04 Friday
    • Boozyuzi
      B&W 805S's - magnetically shielded ?
      by Boozyuzi
      Hi there, new member here.
      I am thinking about changing my N805's for a pair of 805S's. I know that the N805's are shielded and that the 805 sigs are not. So, does anyone know if the new 805S's are magnetically shielded ?
      thanks.
      12 January 2006, 11:36 Thursday
    • AwArEnEsS
      Has anybody listened to Klipsch 115SW subwoofer?
      by AwArEnEsS
      Has anybody listened to Klipsch 115SW (Klipsch Reference Series I think) subwoofer?What do you think about it?
      I could find only one professional review of it:
      http://www.areadvd.de/tests/test-kli...die-messlatte/
      (you can translate...
      12 April 2015, 21:10 Sunday
      Club Klipsch
      I'm up for starting a Klipsch club here for talking about big Klipsch topics. My entire theater project in Home Theater Builder Magazine will be made audible purely by Klipsch. (except for maybe another subwoofer)
      I've really come to appreciate the efficiency of Klipsch, not requiring...
      23 May 2003, 03:59 Friday
