settings for rear channels
  • gopies
    • Mar 2004
    • 12
    Sorry if this sounds silly but just wondering how people set up their rears. Have B&W 704 fronts and HTM7 centre with Wharefdale Valdus 400 as rears driven by Rotel rsp1066/rmb1075. Fronts ~ 4 metres from listening position and rears ~ 1.8 metres. On the preamp I initially had the test tone @ 0dB for each channel. They sounded pretty similar albeit not done with an spl meter. Apart from T3 and lion king many other movies I have listened to don't seem to use the rear channels all that much. On occasions I get and and you can hear things but it is ridiculously low. It all seems odd given that the test tones don't differ all that much. Given that this is my first foray into ht - is it my setup or the mere fact that many soundtracks don't use their rears all that much?
    What are peoples thoughts?
    Regards
    Gopies
    Hi Steve, welcome to The Guide! :later:
    Three thoughts here: First, get an SPL meter. It's amazing how much variance in sound level your ears will NOT pick up on. Second, use a disc-based series of test tones, ie. Video Essentials, AVIA or the like. The internal test tones on a receiver/pre-pro are okay for getting it close, but to get a true reading on SPL levels for a DVD source, you should use a DVD to set them. Try these two things to know you have ablsolutely set the levels correctly. Third, what are the other movies you watch? That may have EVERYTHING to do with the performance you are hearing. If they are newer action-type movies, then you should expect lots of surround activity, if they are old B&W classics, then no, there won't be much - if any - surround activity.
    Hope this helps.
    David - HTGuide flunky
    Our "Theater"
    Our DVDs on DVD Tracker
    • John Holmes
      • 2707
      gopies, Welcome to the Guide!
      David has giving you great info. It is amazing how far our ears can be off when setting the channel levels. I'll just add that, if you do all of what David has covered and you still find them to be a bit low, you may want to check the gauge of wire used to the surround speakers.
      You never mentioned the size of your listening area. I know when i first started out, I was using very thin wire to my surrounds and was having the same issues as you. I was using 22awg wire and changed to 14 awg. My speakers came to life. And the speakers were only about 13ft into the room. Not sure if this is an issue with your setup. Just thought I'd share. Let us know how things turn out.
      • gopies
        • Mar 2004
        • 12
        Hi guys. Sorry for the very late respnse and thanks for the advice. My rears are connected with 12awg wire. I will definitely try get my hands on an spl meter etc. I am sure its the soundtrack, its just weird to hear very soft ambient noise in some movies - I mean either use the rear channels properly or not at all.
        gopies
        • goe2112
          Test tones
          by goe2112
          Does any one know of a website that I can download (free) test tones. I received a SPL meter and would like to check my system with it.
          Thanks for any input.
          09 September 2005, 09:52 Friday
        • CaptainCharisma
          Calibration levels with RSX1055 (DVE vs internal test tones) Huge difference in level
          by CaptainCharisma
          Equipment RSX1055/RMB 1075 RS SPL digital
          No software update...
          I have always calibrated my hometheater with internal test tones, but i bought Digital Video Essentials to have the system 100% correct.
          But the level difference is huge.
          I set the volume to...
          24 February 2005, 14:03 Thursday
        • chanlon
          1068 Calibration with SPL from Audio Control
          by chanlon
          Hi guys,
          I just finished calibrating my 1068 using the Rotel Test Tones and a Real Time Spectrum Analyzer from Audio Control. I had the volume on the processor at 66 (display) and was looking to balance the speakers to 75db.
          Interestingly, the subwoofer setting is at -8DB...
          21 September 2004, 11:35 Tuesday
        • DrBoom
          RSP1098 test tones
          by DrBoom
          Just got my first 2 Rotel components, namely an RSP1098 and an RMB1075.
          Very happy with both, even though they are severely being limited at the moment by my cheap Yamaha speakers which will be replaced with B&W (800 or 700 series) very soon.
          Only 1 thing i can't get to work, the speaker...
          10 December 2003, 18:53 Wednesday
          Measuring response with SPL meter and laptop
          by Andrew Pratt
          Given that I'll be tweaking my tumult sub in the next day or so I wanted to ask you guys what's the easiest way to measure freq' response directly into my laptop? I have the SPL meter and a cable to connect to my soundcardbut which software should I be using...preferably freeware :W I remember doing...
          03 November 2004, 11:09 Wednesday
