What Pre-pro's Cure Lip Sync Problems?
  • Chris Cargen
    • Dec 2003
    Besides the Rotel RSP-1098 and Anthem AV20, what other Pre-pro's cure out of sync Audio with Video?
  • Burke Strickland
    • Sep 2001
    • 3161
    Both the Integra DTC-9.4 and the Integra Research RDC-7 allow the user to adjust for unwanted asynchronous video and audio tracks. The DTC-9.4's A/V Sync functions in a range from 0.0 ms to 74.0 ms in increments of 0.5 ms with a default of 0.0 ms. The Integra Research RDC-7's A/V Sync functions in the range of 0.0 ms to 120.0 ms in increments of 0.5 ms with a default of 0.0 ms.
    For more information on the DTC-9.4 and other Integra Home Theater products: http://www.integrahometheater.com
    For more information on the RDC-7 and other Integra Research products: http://www.integraresearch.com
    Burke
    • ht_addict
      • Dec 2002
      • 508
      My new Yamaha RX-V1400 supports this feature. I know its a receiver, but it also makes and excellent pre/pro.
      ht_addict
      • Michael Mohrmann
        • Feb 2003
        • 51
        The Lexicon MC-1 (v4 software), MC-8 and MC-12 have the feature, from 1 to 60 ms in 1 ms increments. The MC-1 with v3 software allows for a range from 1 to 30 ms. I would imagine that the Lexicon DC-1 and DC-2 would also have this feature.
        Michael
          • 27461
          Michael, the only adjustment similar to that I could find was a delay on the rear channels. Are you sure about this? If so, I'd like to know the menu path for it.
          Lex
          • Michael Mohrmann
            • Feb 2003
            • 51
            Lex,
            Which Lexicon processor do you have? I previously owned the MC-1 v4 and know that it had the feature, called "A/V Sync Delay" or something like that.
            Michael
              • 27461
              I have the MC-12.
              Lex
              • Michael Mohrmann
                • Feb 2003
                • 51
                I have the MC-12.
                In the MC-12 User Guide Rev. 1, starting on page 3-32, is a section entitled A/V SYNC DELAY. This is the parameter that allows you to delay the audio portion of the MC-12's output by up to 60 ms in order to sync up with the video output. As far as I can tell, this parameter is global for all inputs selected (i.e. DVD1, CD, VCR, etc.).
                To access this menu, traverse the following:
                MAIN MENU -> SETUP -> DISPLAYS -> A/V SYNC DELAY
                Michael
                  • 27461
                  Thanks Michael, I'll check that out!
                  Lex
