How high are your surround speakers mounted and how far are your sides from your rear wall?
  • Sonnie Parker
    • Jan 2002
    • 2858
    Where do you have your surrounds mounted in your HT setup? Does anyone have their sides and/or rears mounted at 8 to 9 feet up?
    EDIT: Also how far from the rear wall are your sides and how deep is your room?
    SONNIE
    Cedar Creek Cinema
    DVD Collection
    BFD Comprehensive Setup Guide
  • George Bellefontaine
    • Jan 2001
    • 7637
    I have a drop ceiling in my HT which makes the walls just a tad over 7 feet high. My surrounds and back speakers are about one foot down from the ceiling.
    My Homepage!
    My Homepage!
    • Sonnie Parker
      • Jan 2002
      • 2858
      George, are your sides directly to the side of or a little rear of or a little forward of your prime listening position?
      Every setup guide or reference I can find (thus far) seems to indicate higher is better for movies while lower is better for mulit-channel SACD and DVD-Audio. I'm more of a movie man so I suspect higher would be okay with me.
      SONNIE
      Cedar Creek Cinema
      DVD Collection
        • 16507
        Mide side and rear speaker are all about 6 feet up from the floor which seems to work for me.
        • Thira
          • Sep 2003
          • 9
          Sonny:
          My sides are approx 9 feet mounted flush on the wall. My rears are approx the same height, the main difference is that they are mounted to a swivel and not the wall. The rear speakers are directly across the room from the front speakers, rt & lt respectively, and angled toward the center of room viewing seating area.
          I am very satisfied.
          • Sonnie Parker
            • Jan 2002
            • 2858
            HI Thira... welcome to htguide. Good to see more people that are close to home. I'm only a little over an hour from Florida.
            I don't think I'd have to worry about the angle because all my surrounds are and will be the PSB Image 10S's which are bipolar and already angled.
            Well it makes me feel more comfortable knowing someone else is at 9 feet and very satisfied.
            Are your sides directly beside you?
            SONNIE
            Cedar Creek Cinema
            DVD Collection
            • Gordon Moore
              • Feb 2002
              • 3188
              Couldn't tell you the height from the floor. I only went about 2 foot above sitting position (based on Dolby's recommendation). It couldn't be higher than 6 feet I suspect....I'll give it a measure when I'm at home.
              You could try mounting you speaks on a tripod and play around with the height that way to see what effect it has.
              "A RONSTER!"
              • Danbry39
                • Sep 2002
                • 1584
                When I got my new on-wall surrounds, my daughter and I took turns for around 45 minutes with one holding them up in different positions, while the other evaluated which position sounded best from the spot we listen. Ironically, the spot each choose was within an inch of the others choice, about a foot behind the listening position and about one and a half feet above the listening position. These aren't bipolar surrounds though. I would experiment like Gordon recommends as the positioning might vary room to room and speaker to speaker.
                Keith
                Keith
                  • Jan 2001
                  • 7637
                  Sonnie, sorry for the slow reply.
                  My dipole side surrounds are about a foot behind the main seating area. The two back wall direct radiator speakers are situated about six feet apart from the center, angled downward slightly toward the seating area.
                  My Homepage!
                  My Homepage!
                  • Kevin P
                    • 10808
                    My surrounds are in the back corners of the room, facing inward. They're direct radiators (regular speakers, not bipole/dipole) on stands that put them at roughly ear level when seated. Due to room depth limitations (and the fact that the couch is against the back wall as well) I can't set them back from the couch or farther than the back wall.
                    Not perfect but it works for now until I can afford a bigger room (house).
                    KJP
                    My HT Site
                    • Sonnie Parker
                      • Jan 2002
                      • 2858
                      I took out the ole measuring tape so I could be more exact and our main listening position puts our ears at about 3 feet from the back wall. Which means I'd probably want to locate the side speakers no more than 3 feet from the back wall.
                      This is kinda how the sides and rears will look (it's not to scale -it's rough):
                      Seems like it would be rather crowed with 4 speakers that far to the rear of the room, but maybe not if they are 9 feet up from the floor. There's not a lot of trial and error to work with here due to room limitations.
                      SONNIE
                      Cedar Creek Cinema
                      DVD Collection
                      • John Holmes
                        • 2703
                        I have a 5.1 setup with di/bi-poles for the rear. I have mine to the sides about 2 ft. above ear level. I try to stick as close to dolby's guidelines as possible. But, rooms are so different, you must get creative in many cases.
                        Maybe you could borrow a ladder or two to place the speakers on. You will get an idea if you prefer them at that height without having to mount them in anyway.
                        • Jsapp
                          • Jun 2003
                          • 28
                          My Mini Monitors (direct ) have the tweeters 7 feet off the floor (about 6 inces from ceiling. They are 1.5 feet in back of the couch . The left surround is tipped down slightly and angled on swivel at the right end of the couch. The right one firers ALMOST straight across (just a little tip) and aimed at far left.
                          My room as a partial wall that causes some weird reflections thus the tip down on one speaker.
                          Seems to work OK.
