DirecTV problem
    • 27460
    DirecTV problem
    Hey guys. Well, here I am, a supposed expert, stumped. All at once, my directv receiver started acting up.
    The image for satellite, looks kind of like a film that isn't filling the frame quickly enough. not rolling, just sort of like a strobe light really, flashing bright then dark, fairly fast.
    Strangely, as I recall, my base screen picture when you first changed a channel was normally a blue screen, and yet now it's green! Then the image comes up. My transponders all seem ok, signals in the 90s. signal locked. I am perplexed, unless it's a bad receiver or LNB.
    Any ideas folks? I may swap out with another receiver and see if that fixes the problem, I do have 2 additional ones, but that requires a call to DTV. So, thought I would seek input first.
    My signal goes through a TiVo. I changed the S-video cable from the DTV receiver to the TiVo, no change. TiVo integrates my cable signal (which is fine), and directv, outputing 1 S-video signal from the primary lexicon outputs. Thus, I know it's not the Lex, nor the cable out of directiv or tivo, since the cable picture is fine, and two cables did the same thing on the DTV receiver.
    Lex
  • Chip
    • Aug 2001
    • 232
    Lex,
    First thing i'd do is check the cables at the LNB. Second thing i'd try is swapping out the receiver. My third guess would be the LNB. Since it's available too you, i'd change those cables at the dish (the short ones). Replace them with RG6 if thier RG59. These seem to be culprits in many cases. Also, are you sure you'd have to call DTV to swap out the receiver ? I'm not sure why you'd have to do that unless ofcourse, they aren't activated.
    Chip Engle
    "Concrete ain't a spectator sport"
    <a href="http://www.htguide.com/bilder/index.cfm?fuseaction=arkivbilder&userid=0&selected userid=336" target="_blank">My HT
    Chip Engle
    My HT
    • Sonnie Parker
      • Jan 2002
      • 2876
      Do you have a switch on your system Lex? I had a problem with my Sat picture acting up and ran and switch test and it fixed the problem, but I have Dish Network and have a switch.
      As Chip says, RG6 is the best but you probably know this being a cable man.
      Dish also recommends no cable runs over 100 feet or problems could arise.
      Do you have drip lines in your cable run? Sometimes water can get into the cabling and mess with the picture.
      SONNIE
      Cedar Creek Cinema
      DVD Collection
      BFD Comprehensive Setup Guide
        • 27460
        Yeah Chip, these 2 receivers are not on file with Directv, I am not paying for them.
        Well, truthfully, last time I worked on the cable at the dish, the project went a bit to fast, and I never really got my cable situated. So, it could be water. Sure, I have all the stuff to redo, whatever is wrong, but replacing the line under the house. That one would require a bit more fuss.
        Ideally, I was hoping someone could say, yeah, same thing happened to me, what fixed it was.......
        In the end, I was being lazy, trying to avoid extensive troubleshooting, that I really don't have time to fool with right now.
        What switch are you talking about. I don't know what you mean.
        thanks guys,
        Lex
        • Robbie
          • 256
          Lex
          Are you still having trub with your receiver???? Just a couple of points I'll add.
          Did you try the simple...turn off then unplug the unit to reboot it? I have a Dish player which gets finicky once in a while and just turning it off doesn't do the trick. Have to unplug it to remove all power.
          Does your receiver have a diagnostics menu. I know my Dish player has one, will run a quick self test. Might shed some light on the subject.
          Since you have good signal strength (I guess 90 was normal before) I doubt its a cable issue.
          The switch Sonny was refering to is used to route the signal to multiple receivers. Dish uses these don't know about DTV.
          Hope this helps
          Robbie
            new DirecTV setup in house
            by Lex
            Well, I found myself in a situation where my DirecTV receiver went out on me a couple of months ago. Now, I did have an old receiver on hand that belonged to my Sister Terry, so I transferred my service over to it after they sent me a new card. They won't let you activate a card that's been active before...
            03 July 2003, 23:06 Thursday
          • aaron
            Help! RSP-1068 & DirecTV Sound Issues
            by aaron
            I have tried everything I can think of but I can't figure this out.
            I have a DirecTV Tivo (Hughes branded) box connected to the Optical 1 input on my RSP-1068. The sound quality through the preamp is horrible. I have the default sound mode as "pro logic II cinema". The sound...
            14 March 2006, 23:35 Tuesday
            DirecTV problem
            by Lex
            I dunno, PC satellite signal is good. So, dish hasn't changed alignment much, and satellite PC is much more sensitive to exact positioning than directv. So, I dunno, I tried the other side of my dual LNB, no change, I tried tipping the dish a bit, thinking it might be signal reception, no change. It's...
            20 July 2002, 20:07 Saturday
          • Lexman
            TiVo, An Early Adopter's Tale
            by Lexman
            Folks, it&#39;s been maybe 8-10 months since TiVo was introduced, on the heals of Replay TV. At least Replay was advertised as &#34; Coming&#34; , some time before I had heard of TiVo. Actually, I think the first I heard of TiVo, was the night I bought mine. How&#39;s that for a spontaneous...
            22 August 2000, 21:31 Tuesday
            DirecTV, we should have a choice of ownership
            by Lex
            It came to my attention last year, that if you wished to receive the new local high definition channels through DirecTV, that you must now LEASE a new HDDVR, instead of buying as we could previously through vendors such as TiVo brand products.
            Myself, TiVo had become as much a part of...
            15 March 2008, 10:45 Saturday
