weird cut off problem
  • Greg Stone
    • 895
    Tonight while watching "The Rookie" on DVD, my Denon AVR3300 just shut itself off right in the middle of the movie. I tried to get it to work again immediately, and the power would come back on, but as soon as it was going to start sending sound out, it would shut down again. It has never done this before.
    I unplugged it for about 5 minutes, and tried it again. It shut itself off again. Unplugged it again, and left it unplugged about 30 minutes. It is now working fine again, and has worked for over 3 hours as I caught up on some of my Sopranos DVD's.
    Any idea what the heck happened? I could see no speaker wires touching, and it gets adequate ventilation. The only thing that seemed weird was the power cord was at a hard angle after I had pushed the receiver back, so maybe the bend in the cord was hurting it somehow? Just don't see how since this just problem just started, and the receiver has not been moved in months. Had it well over 2 years now, and don't think it is covered under warranty anymore, but would have to try and find the paperwork.
    Anyone ever have something similar happen to them?
    Greg
    Greg's DVD's
  • John Holmes
    • 2707
    That is strange Greg. I've not heard/read of this being a problem with the 3300. Let's hope it was just sun spots! :B
    • Uncle Clive
      Former Moderator
      • Jan 2002
      • 919
      Greg is it possible to give that power cord some slack? Althouh you cannot see any damages outside the unit, it may very well be inside near the regulator. However, it's not very expensive to replace. If it should shut down again to prevent any further damages, don't try to re-start it, get it serviced. Also, check your speaker cable connections at both ends.
      CLIVE
      CLIVE
      • SiliGoose
        • 941
        Is it possible it went into protection mode and shut off? I've had receivers do that from time to time when I got a little overly aggressive with the volume.
        -Sili
        www.campmurphy.net
        • Greg Stone
          • 895
          Sili - it might have, but I believe I was playing it at -15, and reference is at -10 on my system. I also thought it went into a protection mode, but still can't figure out for what reason.
          Greg's DVD's
            Greg,
            Do you normally listen at the level you were using when the receiver shut down? If so, it probably isn't Protect mode. If you normally listen at a lower level, it could well be the Protect mode. Were you having one of our famous little Texas T-storms at the time? If so, you could have had a power fluctuation which caused it to shut itself down.
            David - HTGuide flunky
            Our "Theater"
            Our DVDs on DVD Tracker
            • Greg Stone
              • 895
              Yes, that is about the level where I normally listen to movies, and yes, we were having some storms now that I think about it. Nothing else shut down power wise, so I didn't think about that. I also have my ht stuff run through a surge protector and a power conditioner, but that still could be the answer.
              I'll let everyone know if it happens again. Thanks for the responses.
              Greg's DVD's
                RIAA at it again!
                by Lex
                How ironic, I copied the article. However, I will give due credit to CNN. Anybody think invasion of privacy here? I sure do. Why doesn't the music industry accept the slow economy like all other businesses have to? No, they are always looking for someone to blame. Well, don't blame me, I buy my music,...
                25 June 2003, 19:09 Wednesday
              • june
                Damages?
                by june
                Hello All,
                Anybody watching "Damages?" So far it's keeping our interest.
                16 August 2007, 12:26 Thursday
              • Dave999
                Help CA-M400s shut down
                by Dave999
                I just had a pair of CA-M400's installed and also have a CAV 180 for the other five channels of a home theater system. During a movie, they all seemed to shut down. The balanced light on the CA-M400s is blinking red and the Green light on the front of the CAV 180 is blinking also. I shup them down...
                11 July 2007, 18:33 Wednesday
                Message for Greg Yeatts
                by Lex
                Greg, I tried to email you 2 times, but something happens and they bounce back. You have 2 usernames and passwords now, let me know by phone if necessary if you can't get in now.
                Lex
                865-405-3684
                02 May 2002, 21:34 Thursday
                Greg Normal playing a chain saw wedge?
                by Lex
                Of course, Greg Normal's golf playing hayday is over, as he's 59, but over the weekend, he almost ended playing golf forever. He accidentally swiped his hand on a chain saw! A guy with a 50 million yatch or something chain sawing his own trees? Does not compute. But he was, and the limb kicked...
                15 September 2014, 20:02 Monday
