I am looking for a sound bar for around 300.00 for my Son In Law. He is in a place where this is the only option while his nice 5-1 set up sits in the garage:M
Need a Sound Bar for 300.00
Tags: None
He just has a 9 month old and has baby proofed the house. He will be putting his nice 5-1 system back in a year or so. Thats why along with a new baby he does not want to spend much money right now.There are two holes in Daddy's head where all the money goes.- Bottom
Check out
This Vizo at Costco on sale for $149.
http://www.costco.com/Vizio-SS2521-C...100214807.html
I didn't get a chance to listen to this but was considering it as I like the flat design, and I recall seeing that it can withstand the weight of a TV. I think it was rated at 55 lbs.
Or
This Yamaha ATS-1050BL Bluetooth Soundbar. I got it at Costco when it was on sale. It is now $189.99.
http://www.costco.com/Yamaha-ATS-105...100222941.html
Spec wise, the Yamaha is rated at 55Hz to 160Hz for the sub and 4kHz to 23Khz for the tweeter section, per the manual. Hmm, if I had checked the manual before purchasing, I might have gone with the Vizo. There's a pretty big hole in the frequency response. But for my purposes, using in the bedroom, it works pretty good. It did go pretty loud at the store and when I hooked it up in the living room.
The Vizo specs show a 55Hz to 19kHz.
These are both one piece sound bars. No separate subwoofer to connect and for kids to get tangled up. You can wall mount the Yamaha.Paul
There are three kinds of people in this world; those that can count, and those that can't.- Bottom
by comeupSometime next year i'm thinking of buying a plasma to put over the fire place in my family room, Costco has installers that charge 350.00 to install and if i'm not mistaking will run cables in the wall if I already have ac outlet in the wall.
Has anyone used Costco installers...-
Channel: Spaced Out
by CliveWhen you live in Toronto and hear the weather report for a Sunday in April to hit 18 degrees C..........you can only think of one thing and one thing only
BAR-B-Q time!!!! :T
So on Saturday I went to the butchers picked up 6 racks o' ribs then to the grocers for some yukon...-
Channel: Spaced Out
by Gordon Moorereprinted from: http://www.audioholics.com/productre...eases2003.html
Yowee...talk about value :T
The receivers will be shipping with microphones.
"A...-
by OldtexasdogMy question is as my folks have a Sony BDP-BX37 and I believe it will only do bit stream with HDMI. (Also as this is my 85-year-old parents set with a 42" LG LED LCD TV that has only one opt dig output that then would go to the sound bar of my choice.) With all I have read and gone out and auditioned...-
28 January 2011, 13:47 Friday -
by P-DubCheck out the new Yamaha RX-V receivers.
Yamaha RX-V series products
Yamaha comparison chart
The RX-V1300 is really loaded and $100 less msrp than the current RX-V1200.
RX-V1300 - msrp US$799
FEATURES
- High Power 6-Channel
- Loading...
- No more items.
