Sherwood P-965 pre-pro not working - may need new pre-pro
  • Kevin P
    • 10812
    I finally spent the day getting the home theater hooked up in our new SC house. And discovered that my workhorse P-965 isn't working. It powers up, the display lights up and it goes to the selected input if an input button was used to turn it on, and then nothing. No sound, and no buttons or remote signals respond. I tried a factory reset, no dice.
    Maybe I'll pop the cover and see if anything is loose inside, but I may be shopping for a new pre-pro or receiver. What are good ones that aren't too expensive these days? Prefer a prepro, but a receiver with pre outs would work too. Maybe it's time to upgrade anyway since the P-965 doesn't do HDMI or the newer audio formats.
    Thoughts?
  • Kal Rubinson
    • 2109
    Budget?
    Kal Rubinson
    "Music in the Round"
    • Kevin P
      • 10812
      $2k max but under $1200 preferred.
      First I'll see if I can get the 965 working.
      • Kevin P
        • 10812
        Success! P-965 is up and running, and sounds great!
        Now I won't have to spend money on a new pre-pro, for at least another year or so.
        • Ovation
          • 2204
          Congrats. Was it a mis-set switch or something? I had a buddy wanting to throw out a receiver some years ago because he was getting no sound. Turns out a muting button was pressed (very tiny, so he didn't notice it until I showed it to him--nearly 10 years on and he's still using it).
          • Kevin P
            • 10812
            No, some connector was probably not connecting right. Carrying it to the shed "fixed" it. I opened it up and reseated all the cable connectors inside, and it's been working fine since.
            I'll probably still upgrade in a year or two, just to get back into the modern era (HDMI, HD audio formats, network/streaming features, etc).
              Here's a :banana: to the new HT setup. Now you just need to upgrade!!!
