Need help planning HT speaker options to build.
  • AllenMueller
    • Nov 2012
    Hi guys - I'm new here!
    So, I'm planning a homebuilt home theater / stereo music listening configuration for my living room.
    The room has solid wood t&g ceiling and hardwood floors (no attic) the space can be described as very open and connected to several rooms without doors.
    The room in the diagram is 15' wide by 23.5' deep with the screen on the 15' end of the rectangle. Ceiling is at a low pitch from about 9.5' to 10.5' across the width of the room. As mentioned, this room has many openings to adjacent rooms. A hallway to another part of the house, an exterior door, a skylight opens the top half of the wall between the home theater room and kitchen and two open doorways also lead intoto the kitchen, which is another 15' x 23.5' space next to the living room.
    Current viewing distance is 11 feet, but we have been thinking about moving back a foot or so. We do plan to eventually upgrade to either LCD of the same size, or a projector with a huge screen, but not for another year or so.
    some background: I'm getting tired of headphones. I work from home and during the day I want to listen to FLAC or otherwise high resolution versions of my favorite electronic ambient music while I'm working. (I have some FLAC files saved up, but have not had a chance to hear them) Most of the music I listen to is devoid of vocals but has layers upon layers of digitally manipulated acoustic recordings ranging all throughout the frequency band, so I am interested in reference quality sound because I've never had the luxury of listening to speakers that didn't bother me after a while or make me feel like I couldn't hear part of the music - and I've got all this great music! So far, all I can find that doesn't bother me is nice headphones turned down to a moderate level. We also watch lots films in the evenings on almost a daily basis, so the system needs to serve both HT and music listening purposes.
    I've been casually searching the internet on and off for a couple years. Actually, I got a little sidetracked and ended up building http://www.prosoundweb.com/article/l...pecs_and_more/ - a set of 4 labhorns, 250 lbs each, for the purpose of producing really loud bass at frequencies nearing 28hz for a DJ friend (they sound great, but require two 5,000 watt class D amps in order to run properly, and transporting them is a bit of an ordeal.) SO yeah - I totally forgot about the HT project, BUT I learned a lot about speaker building and look forward to using those skills again. So, now is the time to get it done, while my clients aren't as business focused as they are during the rest of the year.
    While sifting through a sea of subjective reviews and opinions and so forth, I learned about Linkwitz and Zaph Audio as well as a few other speaker designers who approached things with an objective scientific mindset and found ways to produce reference quality sound on a reasonable budget. Keeping an eye out for anything else out there along these lines, I sifted through everything I could find for a few more days, eventually arriving back at the John Krutke and his ZA5 family of loudspeaker designs. http://zaphaudio.com/ZA5/ and Madisound's convenient package deals that set you up with everything needed to build these excellent loudspeakers http://www.madisoundspeakerstore.com/zaph-audio/
    Going by John's advice concerning choosing and placing the ZA5 speakers, I have developed three possible setups to run in my living room. Though there's lots of room in the space, I don't really have anywhere to put additional surrounds other than two rear surrounds hanging from the ceiling, so I'm shooting to stick with 5.1 audio for now. Keeping that in mind, I created three scenarios (the first being the best, and so on) that just happen to have descending price points, any of which I can meet. The thing that is stumping me is that the setup I want the most, based on what I read at the Zaph Audio site, is quite possibly not going to be effective in my living room. That is where I need your help!
    If you look at the floor plan for my living room, supplied previously in this cavalcade of logharrea, you will see that I have the MMTMMs located with their backs about 12-14" away from the wall and a foot or two from the sides of the television. (The center channel doesn't show because it's sitting below the television.) Finally, the surrounds are mounted to the ceiling and can hang as low as two feet from their mounting point. I don't know if this means I'll need to use the reduced BSC crossover or not, but I plan to position them as little as one foot from the ceiling pointing in whatever direction you guys advise.
    Scenario I - MMTMM front L/R channels
    (best HT / best MUSIC)
    Onkyo TX-NR3009 - 1500
    Home theater receiver with 3D-ready HDMI switching, Internet-ready
    amplifier for added power to front left and right speakers. $700
    speakers - zaph audio / madisound
    za5.5tt - pair - front channels - 550
    za5.3c - single - center channel - 170
    za5.2 - pair - rear channels - 245
    sub with passive radiator - 550
    MDF - 300
    wire - 200
    power conditioner(s) - 200
    $4500
    I originally created this scenario because I wanted to get the best sound for the buck, and this 'sounds' like the best value for a high-quality build-it-yourself system out there - especially if I invested in a premium 4ohm amp to run the MMTMMs when playing music. However, I read in John's notes about the MMTMM - and many other designs in the ZA5 collection - require 2+ feet of space from the wall to the back of the speaker (or in one case the "front of the baffle" was mentioned as the point to measure to.) Anyway, my point is that the front of my DLP is around 2 feet away from the wall and it just seems like it would be awkward to have this huge speaker sitting that far out into the room. So, I am worried that I could just be doing it wrong by attempting to rationalize running the MMTMMs. Nevertheless, this is the configuration that I prefer, because it offers the possibility of enjoying really clear music and films at moderate listening levels.
    Scenario II - MTM x 3 up front
    (great HT / okay music)
    za5.3c - triad - left, center and right front channels - 500
    MDF - 300
    wire - 200
    $3500
    This scenario compensates for the issue with the front left and right channel placement requirements. The 5.3c is supposed to be fine for use as front left and right channels when there isn't room for 2+ feet of clearance form the back wall, but there is the commonly-mentioned issues associated with MTM loudspeakers to deal with, which leads me to scenario III:
    Scenario III - MT satellites
    (great HT / okay music?)
    Onkyo TX-NR818 - 850
    za5.3c - single - center channel - 500
    za5.2 - four - front and rear L/R channels - 245
    ported sub - 445
    MDF - 200
    wire - 200
    power conditioner - 100
    $2500
    Going by John's loudspeaker placement criteria for ZA5 loudspeakers, this arrangement might not be that great for really turning up the music, but it should be more forgiving about placement issues and do an excellent job with movie sound. Also, I wanted to add that I know nothing about tuning or choosing subwoofers to mate with a system, so I chose the most interesting thing I could find at Madisound in the hopes that it will perform as well as the reviewers claim on the Madisound site. That is the subwoofer listed under the speaker kits in each scenario.
    So guys… what should I do? Let me know if you see other flaws or possible blindspots. Let me know if you need the dimensions of my living room or something like that. I'm going to put a lot of effort into the aesthetic portion off this project, so I don't want to wish I had taken a different direction. That's why I came here!
    P.S. - let me know if I'm wayyyy off track. I'm really open to anything. The direction I'm going might not be the right one.
  • AllenMueller
    • Nov 2012
    Wow, great forum. I wrote this up to be clear about my question. Oh well...
      • 16128
      You waited a couple hours and didn't get a response and then threw a fit?
        Heheheeee... Patience, young Padawan. I think you need to give people at least a few hours to read your message... internet forums are people, not automation that is able to give an answer right back instantly. I'm one of the people on here more than others, and even I don't monitor the Guide 24/7. I would imagine you could understand that a lot of people are only able to check the internet once a day or even less.
        Working through your post in order:
        Welcome to the Guide! :banana:
        Your link doesn't work for your room diagram. From the description, though, it sounds like it's somewhat "low" on a scale of being ideal for an audio/video room, with the solid surface floors and ceiling, open walls, and skylight. However, we all work with what we've got--very few people get a truly "ideal" blank slate to work with. The size of the room is good, though, and your proposed seating distance, although you don't say how big your video display is, which is one of the primary factors for viewing distance. Yes, when you can afford it, I'd recommend going for a big screen projector setup, if you want this to become a "real theater".
        That's AWESOME that you built your own speakers! Have you stopped by our "DIY" section here to talk to the guys? They're some of the best experts out there for DIY projects.
        5.1 audio is just fine for a setup, and I don't hesitate to use it in a lot of people's setups that I advise on. Whenever somebody can do 7.1 functionally, that's great, but it's not always possible or worth it.
        Again, your diagram link doesn't work, so I can't see the layout. But it sounds like your plans for option #1 are fine, and if that's what you want to do, then I'd say go for it! Going back to the subject of "nobody's setup is perfectly ideal", that also goes for speaker placement. As you point out, most speakers, to get perfect imaging, should be placed a couple feet away from the wall. But think about it--other than very rich people with large, perfect theater rooms and extra space to spare, who has the ability to sacrifice a big part of a room by pulling speakers several feet away from a wall? Some people. But not many.
        So I say, go with the setup that you want to go with, and then make it work AS BEST YOU CAN in your room. You're not way off track. But even if you got other speakers, they're still going to have to be pulled a distance away from the wall to be in an "ideal" position. So why not get the speakers you want? If you have to place then 10" away from the wall to make your room work, then it's not like they're going to stop working. It's almost certain that they're not even going to sound "bad". They just might not give you 100% performance.
        Hope this helps.
          Allen, you there? I'd hate to think you ran off after a few hours and didn't wait for a response.
            • 16128
            I guess he expected everyone on this forum that doesn't get paid to, to sit around and immediately answer questions.... :B
              Allen?
              Want to give you every chance here.
              • bunshi
                Live next to madisound, compared Idunns and ZA5.3s, questions about power response
                by bunshi
                I'm new here (see the bottom for unimportant information about me).
                I'm debating about building Mark K's ER18DXT or buying the ZA5.3s since the cabinets are currently 77$ off. As a relative new guy to DIY speakers, the ER18DXTs seemed really attractive because of the waveguide tweeter,...
                26 September 2012, 20:50 Wednesday
              • jwalters09
                Zaph ZA5.3 nearfield?
                by jwalters09
                I am looking to build a pair of speakers to be used mostly for music. I have looked around for some designs and really like Zaph's ZA5.3 design. However, I am worried that the way I plan on using these speakers may affect this choice. I do most of my listening with my desktop computer. This computer...
                31 December 2010, 17:12 Friday
              • impulse
                Building Zaphs ZA5.2 and ZA5.3c
                by impulse
                This is my build thread of the Zaphaudio ZA5.2 (br-version) and ZA5.3c. I'll give a short description of my impressions of these speakers when finished. I usually build speakers in MDF, but this time I wanted to try something different. The baffle and the removable back panel was made...
                19 March 2010, 04:34 Friday
              • spartan711
                Zaph ZA5.2 TM DIY Kit
                by spartan711
                Hi Everyone,
                Been interested in DIY speakers for a long time, but this is my first post. Me and my roommates want some speakers for music/movies in our new apartment, and I thought "Finally! Maybe I can indoctrine them into DIY speakers..." :-D
                Here's what I'm debating....
                24 September 2011, 16:27 Saturday
              • Ntruder
                Zaph ZA5.2 build thread
                by Ntruder
                Since I got so much information from this site before choosing which speaker project to build, I thought I'd post pictures of the process for anyone else who might be looking to do the same.
                After months and months of research without making a decision, I decided to go with the Zaph ZA5.2...
                05 June 2010, 13:20 Saturday
