This is my build thread of the Zaphaudio ZA5.2 (br-version) and ZA5.3c. I'll give a short description of my impressions of these speakers when finished. I usually build speakers in MDF, but this time I wanted to try something different. The baffle and the removable back panel was made of 19mm MDF (about 3/4 inch) and the rest (top, left, bottom and right panel) was made of 18mm glued joint oak.
I didn't want any end grain in the joints, so I cut all the oak panels at 45 degree. An important side-effect (in addition to the look) is a bigger area of the glued joint (about 40% bigger than a 90 degree joint). Thus the joint will be much stronger.
Furthermore I wanted the wood grain to follow exactly from left panel, over the top and right panel. To do this you have cut all the panels for one speaker form one piece of board and carefully mark every panel in the right order.
From the board cutting:
There is no room for any errors in the process of cutting these boards. First you have to make sure that the cutting angle is exactly 45,00 degrees. Even a very small error will double up when gluing them together and you'll end up with either a angle that's not 90 degrees or a bad joint where the panels isn't in good contact with each other.
The panels also has to be cut to a perfect rectangle and exactly the same size. Once again, if you screw up any of this you'll have serious trouble with the assembly and end up with a box that is not a rectangle, combined with gaps in the joints.
Be aware of one fact: small enclosures are much easier to build then big ones. Actually, it is the depth of the enclosures that determined how accurate you must be. I started with the 5.2 to get the some practice before the 5.3c.
Finished panels for the 5.2:
Assembling the panels are fairly easy, but you need to be very accurate. I use a couple of templates to make sure that every thing is at right angles.
Images not available
Assembly of the 5.3c:
Image1 not available
Basic enclosures finished:
