using in ceiling for back 4 channels when against rear wall?
  • clearwaterms
    • Nov 2006
    • 110
    I am getting ready to start wiring up my basement for my home theatre. I realize that the space that I have is a comprimise and isn't ideal, however I am hoping everybody can assist me and help me pick the idea locations for the speakers. Also I am hoping everybody can suggest if I should attempt 7.1 over 5.1. I have attached an image of the layout of the space (it is currently in construction so actual pictures are not practical just yet) I plan to use the Dayton inwall speakers that I have read alot of positive reviews about. I am planning on using the 6.5" 2 ways for each of my front three channels and was originally planning on using a pair for the rears as well. I sit along the back wall of the room so I was thinking of using in ceiling for the rear channels.
    Nothing has been purchased yet, so any comments, parts suggestions, etc will be considered. Please remember that I have a little flexability on the price but won't be able to buy $500 a piece in wall speakers since I have currently budgeted the Dayton's at a price of $70 a pair.
  • Kevin D
    • 4601
    I don't think you have the ideal room for 7.1 and I would not have the center rears right above you any way. I would do just a pair of in-ceilings directly to the sides of the couch. Maybe slightly more towards the back wall.
    If Dayton has any angled in-ceilings, that would be better as well.
    Kevin D.
      • 16075
      I'd go 6.1 or go 7.1 with using front height presence channels instead if your receiver supports it. Otherwise the speakers are going to be setup a bit funky.
      • dyazdani
        • 7032
        My parent's living room is set up much the same way, at least as far as the sectional and TV placement. They did exactly what Kevin suggested - you can't quite see the surrounds in this picture, but they're in-ceiling, just off-picture to the left - above and a bit behind the sectional.
        Danish
